All read/write fail on my LimeSDR mini
SDRConsole
Thank you. I tried SDRConsole 3.0.3 on Windows 10 and it works! Thank you very much. I was about to throw away my LimeSDR mini as garbage if you didn’t help me.
LimeQuickTest
I have found Testing the LimeSDR page (https://wiki.myriadrf.org/Testing_the_LimeSDR) and tried the test instruction. EEPROM test still fails though it works with SDRConsole.
$ LimeUtil --find
  • [LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027,
    serial=1D3A0ADAAB2BA2]
$ LimeQuickTest
->Start time: Thu Sep 13 02:45:50 2018
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027,
Serial Number: 1D3A0ADAAB2BA2
->REF clock test
Test results: 2856; 16053; 29250 - PASSED
Results : 6711025 (min); 6711193 (max) - PASSED
->Clock Network Test PASSED
->Read data: FF FF FF FF FF FF FF
→ FPGA EEPROM Test FAILED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.3 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.9 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests FAILED <=
Elapsed time: 2.80 seconds
Finaly :slight_smile:
So Finnaly, what is the problem?
Is it hardware problem? did you capable to resolve ?
Hey, I think I have the same problem, what was your solution?
Solution was to use JTAG cable and program FPGA chip.
Thank you for the answer, but it did not work. I think it is a hardware problem
Hello, yesterday my LimeSDR mini fell, exactly as described by my colleagues :frowning:
I tested on 3 different computers on windows and linux, USB2 and USB3 ports
I have tried all the suggestions in this thread and others
LimeSuiteGui starts but won’t connect to lime
LimeUtil --find = works
LimeUtil --update = not working
can anyone describe how to program JTAG FPGA
LimeUtil --find
Currently my lime is identified (Linux-Ubuntu22) as:
  • [FTDI SuperSpeed-FIFO Bridge, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D421234567890]
LimeUtil --update
Connected to [FTDI SuperSpeed-FIFO Bridge [USB 3.0] 1D1234567890]
libusb: error [udev_hotplug_event] ignoring udev action change
Undefined/Failure
Update not supported: UNKNOWN[HW=0]
is there a chance to fix the lime? is there any service? paid
Thank you for your help
We don’t offer a repair service I’m afraid. Tagging @Zack for JTAG and any other suggestions.
Hi @Jacek,
To re-program the board you will need a cable:
https://wiki.myriadrf.org/LimeSDR-Mini_JTAG_cable_adapter
I suggest to read this thread for more information:
Hello sir, thank you again for your quick reply and willingness to help :slight_smile:
I can send my Limesdr mini where it suits you, with full shipping and service costs covered :slight_smile: I care about LimeSDR Mini because it’s a scarce product and I have a lot of projects on it :slight_smile: and I learned a lot
I wanted to emphasize that the device “fell” itself without any interference from me! but for some time it could not pass FULL tests “LimeQuickTest.exe” whether it is a window or console version
Failure to pass the tests did not cause problems with reception until now when it completely died :(( but it is found in the terminal
“LimeUtil.exe --find”
  • LimeSDR Mini has always been plugged in with the antennas on
  • 97% of usage was receiving a signal
  • I have never connected any amplifiers
  • I did not unscrew the antennas on a working device
  • if I used the “lime” it lasted max 20 minutes
  • I was viewing the spectrum at a speed of max 5 MHz
  • a week ago it was still working (sd++, sdrsharp, sdrconsole, gqrx, gnuradio)
  • the next time you connect to the computer, the device is seen in the computer, but no software wants to connect to it, not even LimesuiteGui, when I select CONNECT, it hangs (linux, windows) 3 different computers (AMD x399 platform, intel platform)
  • FT600ChipConfigurationProg.exe - reads configurations and works
please enter your shipping address and I will send “LimeSDR Mini” with antennas
thank you very much for help :slight_smile:
I’m afraid that we do not offer a repair service.
