I have upgraded the gateware to the latest (GitHub - myriadrf/LimeSDR-XTRX_GW: LimeSDR XTRX gateware project.) using the command ./limeFLASH --device=XTRX --target="FPGA FLASH" <file> (I already had a version of lime gateware) and after that my device is no longer found. By looking at /dev/, the device is no longer listed. Using lspci the device is listed:
02:00.0 Multimedia audio controller: Xilinx Corporation Device 7023 (rev 01)
Subsystem: Xilinx Corporation Device 0007
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Region 0: Memory at e1000000 (32-bit, non-prefetchable) [size=1M]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit-
Address: 00000000 Data: 0000
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s, Exit Latency L0s unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis- NROPrPrP- LTR-
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: litepcie
Kernel modules: litepcie
dmesg shows the following (I’ve enabled all the driver debug flags)::
[ 0.201879] pci 0000:02:00.0: [10ee:7023] type 00 class 0x040100
[ 0.201911] pci 0000:02:00.0: reg 0x10: [mem 0xe1000000-0xe10fffff]
[ 0.202118] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.202171] pci 0000:02:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:1c.2 (capable of 8.000 Gb/s with 5.0 GT/s PCIe x2 link)
[ 9.375033] litepcie 0000:02:00.0: [Probing device]
[ 9.375106] litepcie 0000:02:00.0: BAR0 address=0x000000005fe64184
[ 9.375111] litepcie 0000:02:00.0: csr_write: 0x00000001 @ 0x00000000
[ 9.392606] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006800
[ 9.392617] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006804
[ 9.392623] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006808
[ 9.392628] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000680c
[ 9.392633] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006810
[ 9.392638] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006814
[ 9.392643] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006818
[ 9.392648] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000681c
[ 9.392653] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006820
[ 9.392658] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006824
[ 9.392663] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006828
[ 9.392668] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000682c
[ 9.392673] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006830
[ 9.392678] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006834
[ 9.392683] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006838
[ 9.392688] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000683c
[ 9.392693] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006840
[ 9.392698] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006844
[ 9.392703] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006848
[ 9.392708] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000684c
[ 9.392713] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006850
[ 9.392718] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006854
[ 9.392723] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006858
[ 9.392728] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000685c
[ 9.392733] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006860
[ 9.392738] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006864
[ 9.392743] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006868
[ 9.392748] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000686c
[ 9.392753] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006870
[ 9.392759] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006874
[ 9.392764] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006878
[ 9.392769] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000687c
[ 9.392774] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006880
[ 9.392779] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006884
[ 9.392784] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006888
[ 9.392789] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000688c
[ 9.392794] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006890
[ 9.392799] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006894
[ 9.392803] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006898
[ 9.392808] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000689c
[ 9.392813] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068a0
[ 9.392818] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068a4
[ 9.392823] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068a8
[ 9.392829] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068ac
[ 9.392834] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068b0
[ 9.392839] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068b4
[ 9.392843] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068b8
[ 9.392848] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068bc
[ 9.392853] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068c0
[ 9.392858] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068c4
[ 9.392863] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068c8
[ 9.392868] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068cc
[ 9.392873] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068d0
[ 9.392878] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068d4
[ 9.392883] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068d8
[ 9.392888] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068dc
[ 9.392893] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068e0
[ 9.392899] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068e4
[ 9.392904] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068e8
[ 9.392909] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068ec
[ 9.392914] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068f0
[ 9.392919] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068f4
[ 9.392924] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068f8
[ 9.392929] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000068fc
[ 9.392934] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006900
[ 9.392939] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006904
[ 9.392944] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006908
[ 9.392949] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000690c
[ 9.392954] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006910
[ 9.392959] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006914
[ 9.392964] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006918
[ 9.392968] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000691c
[ 9.392973] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006920
[ 9.392978] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006924
[ 9.392983] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006928
[ 9.392988] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000692c
[ 9.392993] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006930
[ 9.392999] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006934
[ 9.393004] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006938
[ 9.393009] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000693c
[ 9.393014] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006940
[ 9.393019] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006944
[ 9.393024] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006948
[ 9.393029] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000694c
[ 9.393034] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006950
[ 9.393039] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006954
[ 9.393044] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006958
[ 9.393049] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000695c
[ 9.393054] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006960
[ 9.393059] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006964
[ 9.393064] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006968
[ 9.393069] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000696c
[ 9.393074] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006970
[ 9.393079] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006974
[ 9.393084] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006978
[ 9.393089] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000697c
[ 9.393094] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006980
[ 9.393099] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006984
[ 9.393104] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006988
[ 9.393109] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000698c
[ 9.393114] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006990
[ 9.393119] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006994
[ 9.393124] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006998
[ 9.393129] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000699c
[ 9.393134] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069a0
[ 9.393139] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069a4
[ 9.393144] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069a8
[ 9.393149] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069ac
[ 9.393154] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069b0
[ 9.393159] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069b4
[ 9.393164] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069b8
[ 9.393169] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069bc
[ 9.393174] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069c0
[ 9.393179] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069c4
[ 9.393184] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069c8
[ 9.393189] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069cc
[ 9.393194] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069d0
[ 9.393199] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069d4
[ 9.393204] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069d8
[ 9.393209] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069dc
[ 9.393214] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069e0
[ 9.393219] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069e4
[ 9.393224] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069e8
[ 9.393229] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069ec
[ 9.393234] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069f0
[ 9.393239] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069f4
[ 9.393244] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069f8
[ 9.393249] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x000069fc
[ 9.393255] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a00
[ 9.393260] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a04
[ 9.393265] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a08
[ 9.393269] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a0c
[ 9.393274] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a10
[ 9.393279] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a14
[ 9.393284] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a18
[ 9.393290] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a1c
[ 9.393295] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a20
[ 9.393300] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a24
[ 9.393305] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a28
[ 9.393310] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a2c
[ 9.393315] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a30
[ 9.393320] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a34
[ 9.393325] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a38
[ 9.393330] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a3c
[ 9.393335] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a40
[ 9.393340] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a44
[ 9.393345] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a48
[ 9.393350] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a4c
[ 9.393355] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a50
[ 9.393360] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a54
[ 9.393365] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a58
[ 9.393370] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a5c
[ 9.393375] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a60
[ 9.393380] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a64
[ 9.393385] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a68
[ 9.393390] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a6c
[ 9.393395] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a70
[ 9.393400] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a74
[ 9.393405] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a78
[ 9.393410] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a7c
[ 9.393415] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a80
[ 9.393420] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a84
[ 9.393425] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a88
[ 9.393430] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a8c
[ 9.393435] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a90
[ 9.393440] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a94
[ 9.393445] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a98
[ 9.393450] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006a9c
[ 9.393455] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006aa0
[ 9.393460] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006aa4
[ 9.393465] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006aa8
[ 9.393470] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006aac
[ 9.393475] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ab0
[ 9.393480] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ab4
[ 9.393485] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ab8
[ 9.393490] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006abc
[ 9.393495] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ac0
[ 9.393500] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ac4
[ 9.393505] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ac8
[ 9.393510] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006acc
[ 9.393515] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ad0
[ 9.393520] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ad4
[ 9.393525] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ad8
[ 9.393530] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006adc
[ 9.393535] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ae0
[ 9.393540] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ae4
[ 9.393545] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ae8
[ 9.393551] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006aec
[ 9.393555] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006af0
[ 9.393560] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006af4
[ 9.393566] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006af8
[ 9.393573] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006afc
[ 9.393580] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b00
[ 9.393588] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b04
[ 9.393593] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b08
[ 9.393598] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b0c
[ 9.393603] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b10
[ 9.393608] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b14
[ 9.393613] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b18
[ 9.393618] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b1c
[ 9.393623] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b20
[ 9.393628] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b24
[ 9.393633] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b28
[ 9.393638] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b2c
[ 9.393643] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b30
[ 9.393648] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b34
[ 9.393653] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b38
[ 9.393659] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b3c
[ 9.393664] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b40
[ 9.393669] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b44
[ 9.393673] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b48
[ 9.393678] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b4c
[ 9.393683] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b50
[ 9.393688] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b54
[ 9.393693] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b58
[ 9.393698] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b5c
[ 9.393703] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b60
[ 9.393709] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b64
[ 9.393714] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b68
[ 9.393718] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b6c
[ 9.393723] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b70
[ 9.393728] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b74
[ 9.393733] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b78
[ 9.393738] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b7c
[ 9.393743] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b80
[ 9.393748] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b84
[ 9.393753] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b88
[ 9.393758] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b8c
[ 9.393763] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b90
[ 9.393768] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b94
[ 9.393773] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b98
[ 9.393778] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006b9c
[ 9.393783] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ba0
[ 9.393788] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ba4
[ 9.393793] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006ba8
[ 9.393798] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bac
[ 9.393803] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bb0
[ 9.393808] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bb4
[ 9.393813] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bb8
[ 9.393818] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bbc
[ 9.393823] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bc0
[ 9.393828] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bc4
[ 9.393833] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bc8
[ 9.393838] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bcc
[ 9.393843] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bd0
[ 9.393848] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bd4
[ 9.393853] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bd8
[ 9.393858] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bdc
[ 9.393863] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006be0
[ 9.393868] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006be4
[ 9.393873] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006be8
[ 9.393879] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bec
[ 9.393884] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bf0
[ 9.393889] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bf4
[ 9.393894] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bf8
[ 9.393899] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x00006bfc
[ 9.393901] litepcie 0000:02:00.0: Version
[ 9.394019] litepcie 0000:02:00.0: 1 MSI IRQs allocated.
[ 9.394039] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d000
[ 9.394043] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d004
[ 9.394045] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d008
[ 9.394047] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d00c
[ 9.394049] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d010
[ 9.394052] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d014
[ 9.394054] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d018
[ 9.394056] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d01c
[ 9.394058] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d020
[ 9.394061] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d024
[ 9.394063] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d028
[ 9.394065] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d02c
[ 9.394067] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d030
[ 9.394070] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d034
[ 9.394072] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d038
[ 9.394074] litepcie 0000:02:00.0: csr_write: 0x00000000 @ 0x0000d03c
[ 9.394079] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.404006] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.413934] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.423862] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.433790] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.443717] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.453643] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.463569] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.473494] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.483419] litepcie 0000:02:00.0: csr_read: 0x00000000 @ 0x0000d000
[ 9.493342] litepcie 0000:02:00.0: FreeIRQs 1
The system is Ubuntu 22.04, kernel 6.5.0-28-generic
Any ideas?
