Greetings!
I’m having an issue with a physical xtrx 1.2 device.
I’m wondering if this could be either the device doesn’t have any configuration on it, or perhaps EEPROM / Flash corruption?
The PCIe board and software work fine with a different
xtrx 1.2device. -
My understanding is that this device has never been flashed or even powered on prior to this issue being visible.
I’m using commit
368efb0154a459e42317ae270bf9716e776b82acof LimeSuiteNG to build the kernel module and the relevantlime*CLI tools. -
The device does show up ( with the serial number
00-00-00-00-00-00-00-00) usinglspci. -
Running
limeDeviceresults inLimePCIe: Failed to open (/dev/limepcie0/control0), errno(5) Input/output error. -
Doing a
modprobe limepcie, and subsequentrmmod limepcieresults in the followingdmesg:
[ 2686.631972] limepcie : module init
[ 2686.635501] limepcie 0000:01:00.0: [Probing device] vid:10EE pid:7023
[ 2686.643162] limepcie 0000:01:00.0: BAR0 address=0x000000002e27903a
[ 2686.669657] limepcie 0000:01:00.0: Identifier: \xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff
[ 2686.696487] limepcie 0000:01:00.0: [device info] LimeSDR-Unknown FW:255 HW:255 PROTOCOL:255 S/N:0xFFFFFFFFFFFFFFFF
[ 2686.706980] limepcie 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 8.000 Gb/s with 5.0 GT/s PCIe x2 link)
[ 2686.722351] limepcie 0000:01:00.0: Required DMA mask ffffffffffffffff. Attempting 64bit mask.
[ 2686.730968] limepcie 0000:01:00.0: 1 MSI IRQs allocated.
[ 2686.736308] limepcie 0000:01:00.0: DMA buffer size not specified, defaulting to 8192
[ 2686.744080] limepcie 0000:01:00.0: Invalid DMA channel count(-1)
[ 2686.750108] limepcie 0000:01:00.0: Creating /dev/limepcie0/control0
[ 2725.930712] limepcie 0000:01:00.0: [Removing device] vid:10EE pid:7023
[ 2725.937279] limepcie 0000:01:00.0: FreeIRQs 1
[ 2725.942045] limepcie : module exit
- The relevant section of
lspci -vvvvis below:
0000:01:00.0 Multimedia audio controller: Xilinx Corporation Device 7023 (rev 01)
Subsystem: Xilinx Corporation Device 0007
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at 1b80000000 (32-bit, non-prefetchable) [virtual] [size=1M]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit-
Address: 00000000 Data: 0000
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s, Exit Latency L0s unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x1 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis- NROPrPrP- LTR-
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
Kernel modules: limepcie
An earlier version of the LimeSuiteNG repository using litepcie kernel module seemed to have a similar non-functional response.
Is there something that anyone would recommend other than soldering to the JTAG port?
Thanks!
edit: forgot to mention, the kernel is forcing 32bit DMA ( comes out of this thread ), without it the device is not found at all.
