After installing the limeSuiteNG on the pi, it finds the device as Multimedia audio controller: Xilinx corporation Device 7023 (rev 01) and I cant seem to get the xtrx to work. any idea how I can fix this issue?
Thanks, seems to still have the same difficulties connecting to it for some reasons! After editing the config file, I am still facing the same issue. tried pcie-32bit-dma-pi5 as well, but no luck!
PCIe driver compilation requires linux-kernel-headers, on RaspbianOS the package is called differently, you should try “sudo apt-get install raspberrypi-kernel-headers”. And then recompile and install LimeSuiteNG.
When you run ‘cmake’ for LimeSuiteNG, it should show what features are enabled, like:
LimeSuiteNG enabled features:
HEADERS, The limesuiteng headers
LIBRARY, The limesuiteng library
LITE_PCIE, PCIe support
LITEPCIE_KERNEL_MODULE, Build Linux LitePCIe kernel module
Installed the kernel headers, now cant reinstall the limesuitng! Will work on this to see if I can find the problem, it is having difficulties installing the linux kernel module
47%] Building Linux kernel module in dir: /home/terrawave/LimeSuiteNG/build/src/comms/PCIe/linux-kernel-module
make[3]: *** /lib/modules/6.6.31-v8-16k+/build: No such file or directory. Stop.
make[2]: *** [src/comms/PCIe/linux-kernel-module/CMakeFiles/litepcie-kernel.dir/build.make:73: src/comms/PCIe/linux-kernel-module/litepcie.ko] Error 2
make[1]: *** [CMakeFiles/Makefile2:865: src/comms/PCIe/linux-kernel-module/CMakeFiles/litepcie-kernel.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
the script is attempting to build the module using directory: /lib/modules/`uname -r`/build, check if the /lib/modules/ contains a subdirectory which name matches output of “uname -r” command.
ok, got the kenel working and everyting is reinstalled
[ 3.302290] litepcie: loading out-of-tree module taints kernel.
[ 3.302330] litepcie: disagrees about version of symbol __pci_register_driver
[ 3.302333] litepcie: Unknown symbol __pci_register_driver (err -22)
[ 3.302340] litepcie: disagrees about version of symbol remap_pfn_range
[ 3.302342] litepcie: Unknown symbol remap_pfn_range (err -22)
[ 3.302352] litepcie: disagrees about version of symbol pci_unregister_driver
[ 3.302354] litepcie: Unknown symbol pci_unregister_driver (err -22)
[ 3.302401] litepcie: disagrees about version of symbol kmalloc_trace
[ 3.302403] litepcie: Unknown symbol kmalloc_trace (err -22)
[ 3.302414] litepcie: disagrees about version of symbol kmalloc_caches
[ 3.302416] litepcie: Unknown symbol kmalloc_caches (err -22)
[ 4.845816] litepcie: disagrees about version of symbol __pci_register_driver
[ 4.845826] litepcie: Unknown symbol __pci_register_driver (err -22)
[ 4.845835] litepcie: disagrees about version of symbol remap_pfn_range
[ 4.845837] litepcie: Unknown symbol remap_pfn_range (err -22)
[ 4.845850] litepcie: disagrees about version of symbol pci_unregister_driver
[ 4.845852] litepcie: Unknown symbol pci_unregister_driver (err -22)
[ 4.845904] litepcie: disagrees about version of symbol kmalloc_trace
[ 4.845906] litepcie: Unknown symbol kmalloc_trace (err -22)
[ 4.845920] litepcie: disagrees about version of symbol kmalloc_caches
[ 4.845922] litepcie: Unknown symbol kmalloc_caches (err -22)
[ 5.470826] litepcie: disagrees about version of symbol __pci_register_driver
[ 5.470834] litepcie: Unknown symbol __pci_register_driver (err -22)
[ 5.470841] litepcie: disagrees about version of symbol remap_pfn_range
[ 5.470844] litepcie: Unknown symbol remap_pfn_range (err -22)
[ 5.470854] litepcie: disagrees about version of symbol pci_unregister_driver
[ 5.470857] litepcie: Unknown symbol pci_unregister_driver (err -22)
[ 5.470906] litepcie: disagrees about version of symbol kmalloc_trace
[ 5.470907] litepcie: Unknown symbol kmalloc_trace (err -22)
[ 5.470919] litepcie: disagrees about version of symbol kmalloc_caches
[ 5.470920] litepcie: Unknown symbol kmalloc_caches (err -22)
[ 6.882823] litepcie: disagrees about version of symbol __pci_register_driver
[ 6.882832] litepcie: Unknown symbol __pci_register_driver (err -22)
[ 6.882840] litepcie: disagrees about version of symbol remap_pfn_range
[ 6.882842] litepcie: Unknown symbol remap_pfn_range (err -22)
[ 6.882854] litepcie: disagrees about version of symbol pci_unregister_driver
[ 6.882856] litepcie: Unknown symbol pci_unregister_driver (err -22)
[ 6.882908] litepcie: disagrees about version of symbol kmalloc_trace
[ 6.882910] litepcie: Unknown symbol kmalloc_trace (err -22)
[ 6.882922] litepcie: disagrees about version of symbol kmalloc_caches
[ 6.882924] litepcie: Unknown symbol kmalloc_caches (err -22)
disagrees about version of symbol this indicates that the module was compiled with kernel headers that are different from the kernel that you are currently running. Do you have multiple linux kernels installed?
There is something that was confusing me for a moment. The build scripts seems to use /lib/modules, but the FindLinuxKernelHeaders.cmake uses /usr/src/linux-headers-${KERNEL_RELEASE} to find include/linux/user.h. This causes an issue on Raspberry Pi because of the way how headers are packaged there: they have a lot of headers in the common folder rather than a release version one (i.e. it is /usr/src/linux-headers-6.6.31+rpt-common-rpi which contains include/linux/user.h, and not the /usr/src/linux-headers-6.6.31+rpt-rpi-2712). The /lib/modules/uname -r/source points to the /usr/src/linux-headers-6.6.31+rpt-common-rpi.
Not sure if that causes some actual issues, but it at leads to a confusing message of CMake about missing required packages. Iv’e solved it by passing -DKERNELHEADERS_DIR=/lib/modules/uname -r/source to CMake.
@ricardas Are you aware of some plans to leverage DKMS? It seems that it could simplify some aspects of the kernel module, including making it easier to update the OS after the module has been installed. Maybe there are some non-obvious stoppers, or maybe something we can help you with?
I think the entire ret = ... and the if statement below it needs to be commented. Otherwise ret seems to be initialized to an error some lines above. It didn’t work for me though.
What worked for me to get past the litepcie 0000:01:00.0: arch assigned 64-bit MSI address 0xffffffe000 but device only supports 32 bits error is adding this to the config.txt: dtoverlay=pciex1-compat-pi5,no-mip.From its documentation: Revert to the MSI target in the RC, instead of the MSI-MIP peripheral. Use if a) more than 8 interrupt vectors are required or b) the EP requires DMA and MSI addresses to be 32bit. The latter sounds related.
It allowed to get past this error, and allowed lineDevice to find the device. Unfortunately, the basicRX still didn’t work, as the litepcie_mmap() returned an error: litepcie 0000:01:00.0: mmap io_remap_pfn_range failed -22. Maybe some further work needed, or, maybe is related on some other quirk I have.
@masefi Does the lspci show XTRX after every reboot? For me it is super unreliable, it might take manu reboots to make XTRX listed there. And it only happens on RPi5, using XTRX on CM4 IO board works reliably. So doesn’t seem related on the XRTX itself.
Interesting, thanks for the detailed info Sergey, I will give this a try. For now RPi5 does not detect it as XTRX at all! I have to reboot multiple times to make it detectable as Multimedia audio controller: Xilinx corporation Device 7023 (rev 01). Sometimes the second light on the XTRX board stops blinking (the one furthest from the micro USB port) and either powers or stays on after boot. in either of these cases, it becomes completely undetectable. I have to reboot multiple times to make it detectable as the Xilinx Device
Is there a specific CM4 PCIe module that you use? the only reason I use RSPi5 is the PCIe option.
