I bought the Lime SDR USB recently.
I’ve been trying for days. I have reinstalled Visual C ++ several times, but without results.
Does anyone have experience in a similar case?
Thank you
Magi
Hi Zack
I have installed and uninstalled the Visual C ++ 2015 Redistributable 5 or 6 times.
I have rigorously followed all Microsoft instructions regarding this error.
In the System32 folder I find the vcruntime140.dll, but apparently the system can not find it.
The PC is an Intel I7 64 bits, in motherboard ASUS H81 PLUS operating in W10
I can not think what else I can do.
I will appreciate your help
Regards
Magi
Are you installing 64 bit redistributable? Install vc_redist.x86.exe, while LimeSuite is 32 bit.
Hi Zack
Problem solved !!!
By operating on 64-bit W10, I thought I should keep the format. Anyway, in the instructions I have not found any reference in this regard.
In “Guetting Started” specify an “lte_ini” file that I can not find for more than I searched.
Where can I find it?
Thanks for your help
Regards,
Magi
