UPLOADED .RPD IN MY LIMESDR-mini v2.4 and not working anymore
hi , i have seen a video from signals everywere how this guy update a .rpd to get the latest software/gateware…
now my mini v2.4 does not work anymore???
i have in 5 linux software try to install limesuite ng ( as you are informing )
also in compiling from source fails , PCie kernel errors??
but in radioconda , conda the packages are simply not online (not found)???
so out off the question to repair or reflash the fpga again …with usb connected.
after many hours off thinking and searching only info from you maybe to use a jtag connected to ft2232 ??? so usb limesuite (ng not installable) fails again…??? (nessesary ?)
the gateware that you support does not say in detail what to do exactly , and procedures.
radioconda installs limesuite (no ng) in windows to the latest from oktober this year…
What must be done correctly to reset /FLASH my limesdrmini from 577 euro ???
please note that my information will be shared with many radioamateurs friends from me
Hello on7ndr,
Mini v2 boards do not use rpd files for programming, rpd files are used for Mini V1, so it is likely you overwrote the existing gateware image with invalid data.
Good news is that Mini V2 boards ship with both a user image and a recovery image. So reflashing a new user image without JTAG should be possible.
If the board has booted up into the recovery image, a single LED should be blinking red and the board should still be detectable by the software. Can you confirm if this is what’s happening on your board?
While we recommend using LimeSuiteNG, LimeSuite(non NG) does support Mini boards, so if you’re having issues installing LimeSuiteNG, LimeSuite(non NG) should suffice.
If the software can detect your board, follow this guide to flash an updated user image:
Let me know if this helps solve your issue.
Hello , No led is visible anymore in this brandnew mini v2.4 , so no green blinking or red blinking Led …i have try to load this miniv2.bin into limesuite latest in programming /FLASH FPGA and it says programming failed …the d3xx module still works and finds the lime via the FT601 driver/port… how can this happen that there is no other system to restore without soldering wires to this new board , i do not understand that
also “Limeflash” instructions fail also in enverimont from radioconda Limesuite latest version??
please help
Hi @on7ndr,
Since there is no LED activity, it looks like both the user and recovery gateware images may be corrupted. If that’s the case, recovery through LimeSuite or LimeSuiteNG tools is no longer possible, and the FPGA flash will need to be restored using JTAG.
There is no need to solder wires to the board. You can use a pogo-pin probe clip with jumper wires to access the JTAG connections. These clips are widely available from various manufacturers and sellers. Just make sure the clip has at least six pins in a single row with 2.54 mm (0.1") pitch.
For JTAG programming, you can follow the official documentation, although this requires installing the FPGA toolchain as described in Requirements section.
Alternatively, there is a simpler recovery procedure using openFPGALoader, which avoids installing the full FPGA toolchain. Just make sure to use the correct programming files as described in the guides.
Regards,
Vytautas
2026-11-11T23:00:00Z update :::de on7ndr
Hi all,
Thanks for some information about JTAG stuff /official documentation etc. and unbricking the corrupted limesdr-mini v2.4
i am not a linux guy and do not understand programming language .
So long listed commands do not serve and finding the path in windows etc delivers problems.
So this is what i have done
:slight_smile: try to install msys2 in windows and getting openFPGAloader to work.
Hmmm, after connecting the ft2232h to my pc , in device manager serial converters was active and also many other COM port from ft2232h
Opening ucrt64 and giving the command ;; openFPGAloader --cable ft2232 --write-flash --bitstream ./limesdr_mini_v2.bit hmmm error
"EMPTY " message
“JTAG init Faild”
So that openfpgaloader was not doing magical stuff …
i have also dragged /copied the path from that v2.bit file and zero result…
SO WHAT NOW ? what could i do , windows 11…hmmmmmm problem .
installing the whole toolchain in win…dows?
STOP , i must read more on this forum…
a guy did the trick with diamond lattice software.
after registering i had to wait 2 days before i could access and download this non free 3.14 software …the node-free key (licence) i have not recieved it at all ( not now, hmmm)
after the download from that i have a diamond programmer on my desktop…
these are the steps i have found and done to get it again active and alive…kicking (green led)
NR1 image
connecting the module just like the image above from your jtag v2 information ,many thanks .
BE AWARE THAT ALSO THE LIMESDR mini must be powered with the normal usb2/3 cable to a pc or adapter usb 5 V DURING THE FLASH PROCEDURE . flash procedure fails when NOT usb cable inserted to the mini or from a external power supply phone adapter /5 V max
THE PROGRAMMING /FLASHING INFO
SEE IMAGE 1
START PROGRAMMER “DIAMOND PROGRAMMER 3.14” find icon on your desktop Yellow
Follow the image …self explainary
Download the official github code https://github.com/myriadrf/LimeSDR-Mini-v2_GW/
Download this Gateware . extract it somewhere in Document ..so path is always found…
Start with flashing the SRAM , this is tempory creating a virtual enverimont ( readed somewhere)…after that you will get a GREEN pass in STATUS …
After that i remember well the moment the led was again flashing green …
that happend after flashing in the step 2
STEP 2
after doing this step the mini should be working again …
i do not want to go in a discussion if other methods are better or have more potential.
that has done the trick , i think…
if , and if , the led again does not light up when booting try also step 3 and repeat step 1 and 2 step gain intill you see spi erase , programm , verify … it can realy be working again..dont give up…
STEP 3 (only try when lime does not boot up(no leds) and stays dead again after inserting in to a usb )
That all folks , my lime mini works again and have done a flash with the radioconda newest version to flash the 3.12 GW limesdrv2.bit , that was also working , but not in AUTOMATIC mode note , only FLASH mode
Problem solved .
i hope i have helped also other HAMS who do not have the linux skills
73 DE ON7NDR 12/11/2026
WWE Daniel Bryan's Iconic 'YES!' Chant
