Unavailability of a component from the LimeSDR-Mini_2v4 BOM
Hello everyone,
While reviewing the LimeSDR-Mini_2v4 design, I found that the TCXO (40 MHz, HCMOS, 3.3 V, 0.5 ppm, –40 to +85 °C, ±15 ppm, 5.0 × 3.2 mm) — Part Number E7355LF from Rakon, listed in the BOM is currently unavailable in the market.
Has anyone else encountered this issue?
Could you please suggest how we can source it or if there is an equivalent alternate TCXO that can be used instead?
Thank you.
It could be that it’s a special order item. Have you damaged this part?
We are currently developing a custom board based on the LimeSDR open-source hardware design.
While reviewing the LimeSDR-Mini_2v4 BOM, we found that the Rakon E7355LF TCXO is no longer available through standard distributors.
Could you please confirm whether this is a special-order component, and if there is a recommended equivalent or compatible alternative that can be used in its place?
Thank you.
@Zack should be able to advise.
Yes, it is special order from Rakon.
You should select TCXO according to your application. I have no alternative to suggest, sorry.
Thank you for the clarification, Zack.
