Hello.
I trying to use the ch.A external loopback. However, I not receiving anything. I also tried to activate it with the LimeSuite GUI and transmitted with GNU Radio. In none of these tries I got something on the RX. What am I doing wrong?
My code is below:
import SoapySDR
from SoapySDR import Device
import time
import numpy as np
import threading
def Modify_SPI_Reg(sdr, addr , msb, lsb, value):
spiDataReg = sdr.readRegister(“BBIC”, addr)
spiMask = (~(~0 << (msb - lsb + 1))) << (lsb)
spiDataReg = (spiDataReg & (~spiMask)) | ((value << lsb) & spiMask)
return sdr.writeRegister(“BBIC”, addr, spiDataReg)
def LoopBack(sdr):
Modify_SPI_Reg(sdr, 0x17, 0 , 0 , 1)
Modify_SPI_Reg(sdr, 0x17, 1 , 1 , 1)
Modify_SPI_Reg(sdr, 0x17, 2 , 2 , 0)
def tx():
i = 0
global tx_time_0
LimeSDR1.activateStream(txStream1)
tx_time_0 = int(LimeSDR1.getHardwareTime() + 0.1e9)
while i < 100:
status = LimeSDR1.writeStream(txStream1, [iq0], len(iq0), tx_flags, tx_time_0)
if status.ret != len(iq0):
raise Exception('transmit failed %s' % str(status))
i= i+1
LimeSDR1.deactivateStream(txStream1)
LimeSDR1.closeStream(txStream1)
def rx():
i = 0
receive_time = int(tx_time_0 - (num_rx_samps/samp_rate) * 1e9/2)
LimeSDR1.activateStream(rxStream1, rx_flags, receive_time, num_rx_samps)
rx_buff = np.array([0]*1024, np.complex64)
timeout_us = int(5e5) #500 ms >> stream time
while i < 100:
status = LimeSDR1.readStream(rxStream1, [rx_buff], len(rx_buff), timeoutUs=timeout_us)
i = i +1
LimeSDR1.deactivateStream(rxStream1)
LimeSDR1.closeStream(rxStream1)
np.savetxt('IQ rx.txt', rx_buff)
#Variables
samp_rate = 20e6
bandwidth = 5e6
rx_lo = 2e9
gain = 30
burstSize = 1024
ts = 1/samp_rate
N = 2 ** 16
t = np.arange(0, N*ts, ts)
i0 = np.cos(2 * np.pi * t * 200e3) * 2 ** 14
q0 = np.sin(2 * np.pi * t * 200e3) * 2 ** 14
iq0 = i0 +1j * q0
iq0 = iq0.astype(np.complex64)
np.savetxt(‘IQ.txt’, iq0)
devices = Device.enumerate()
print(devices)
LimeSDR1 = Device(devices[0])
LimeSDR1.boardName = “LimeSDR”
LimeSDR1.setMasterClockRate(30.72e6)
LimeSDR1.setSampleRate(SoapySDR.SOAPY_SDR_TX, 0, int(samp_rate))
LimeSDR1.setAntenna(SoapySDR.SOAPY_SDR_TX, 0,‘BAND2’)
LimeSDR1.setGain(SoapySDR.SOAPY_SDR_TX, 0, gain)
LimeSDR1.setFrequency(SoapySDR.SOAPY_SDR_TX, 0,int(rx_lo))
LimeSDR1.setBandwidth(SoapySDR.SOAPY_SDR_TX, 0, int(bandwidth))
time.sleep(1)
LimeSDR1.setSampleRate(SoapySDR.SOAPY_SDR_RX, 0, int(samp_rate))
LimeSDR1.setAntenna(SoapySDR.SOAPY_SDR_RX, 0,‘LNAH’)
LimeSDR1.setGain(SoapySDR.SOAPY_SDR_RX, 0, gain)
LimeSDR1.setFrequency(SoapySDR.SOAPY_SDR_RX, 0,int(rx_lo))
LimeSDR1.setBandwidth(SoapySDR.SOAPY_SDR_RX, 0, int(bandwidth))
time.sleep(1)
rxStream1 = LimeSDR1.setupStream(SoapySDR.SOAPY_SDR_RX, SoapySDR.SOAPY_SDR_CF32, [0])
txStream1 = LimeSDR1.setupStream(SoapySDR.SOAPY_SDR_TX, SoapySDR.SOAPY_SDR_CF32, [0])
time.sleep(1)
LoopBack(LimeSDR1)
time.sleep(1)
num_rx_samps = len(iq0)
tx_flags = SoapySDR.SOAPY_SDR_HAS_TIME | SoapySDR.SOAPY_SDR_END_BURST
rx_buffs = np.array(, np.complex64)
rx_flags = SoapySDR.SOAPY_SDR_HAS_TIME | SoapySDR.SOAPY_SDR_END_BURST
t1 = threading.Thread(target=tx)
t2 = threading.Thread(target=rx)
t2.start()
t1.start()
t1.join()
t2.join()
