Hi all,
I never managed to make my LimeSDR mini able to transmit, today I’m testing with OsmoTRX-lms and again, no good luck. I just realize that anytime I execute the “LimeQuickTest”, never pass the “RF Loopback”:
root@icarus:/# LimeQuickTest
->Start time: Mon Oct 22 23:17:32 2018->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D393861EF7E64
Serial Number: 1D393861EF7E64[ Clock Network Test ]
->REF clock test
Test results: 4160; 17359; 30555 - PASSED
Results : 6710975 (min); 6711137 (max) - PASSED
->Clock Network Test PASSED[ FPGA EEPROM Test ]
->Read data: 12 01 16 12 01 16 02
->FPGA EEPROM Test PASSED[ LMS7002M Test ]
->LMS7002M Test PASSED[ RF Loopback Test ]
SetPllFrequency: timeout, busy bit is still 1
Failed to set sample rate
->RF Loopback Test FAILED=> Board tests FAILED <=
Elapsed time: 8.19 seconds
root@icarus:/#
Please, could you help me ? Is there anything else I can try ?
Regards,
Pedro
