I am trying to transmit a signal with the LimeSDR USB. Along that, I would like to receive this signal with the Loopback. So periodically, I can compare the phase from two signals generated in two different syncronized devices.
When trying to activate the Loopback, i found some difficulty. I am using the SoapySDR, so I can use Python with more than one devices.
Dealing with the Loopback, I am tried to replicate what the LimeQuickTest does, writing the same registers. However this approach did not work.
Modify_SPI_Reg(sdr, 0x010D, 8, 7, 2) Selects the active path of the RXFE: LNAL path active
Modify_SPI_Reg(sdr, 0x010C, 7, 7, 1) Power control signal for LNA_RFE
Modify_SPI_Reg(sdr, 0x010C, 6, 6, 1) Power control signal for RXFE loopback 1
Modify_SPI_Reg(sdr, 0x010D, 4, 4, 1) Enables the input shorting switch at the input of the loopback 1 (in parallel with LNAL mixer).
Modify_SPI_Reg(sdr, 0x010D, 2, 2, 1) Enables the input shorting switch at the input of the LNAL.
Modify_SPI_Reg(sdr, 0x010D, 1, 1, 1) Enables the input shorting switch at the input of the LNAW.
Modify_SPI_Reg(sdr, 0x0101, 12, 11,1) Controls the loss of the of the loopback path at the TX side
Modify_SPI_Reg(sdr, 0x0103, 10, 10, 1) Enable signal for TXFE, band 2
Modify_SPI_Reg(sdr, 0x0113, 5, 2, 2) Controls RXFE loopback gain
After that I saw on a thread here to write just two registers. As the other try, I did not work.
Modify_SPI_Reg(sdr, 0x0002A,9,8, 2) RX_MUX to TxFIFO
Modify_SPI_Reg(sdr, 0x0002A,5,4, 2) RX FIFO write clock to FCLK1
I would like to understand which approach is the right, one of the two that I presented or other that I do not know.
Also, there is a on board Loopback, outside of the LMS7002. Would this specific hardware be more suitable for my case. If so, how can i activate this hardware.
If someone could help me, I would be grateful.
Thank you.
