Dear Marty,
Thank you for responding to my cry for help.
I have used my 64bits Windows 10 PC. I have installed PothosSDR-2019.06.09-vc14-x64.exe
I run the LimeSuite. Click “Options”, click “Connection Settings” and nothing comes up in the window.
I go to Device Manager. Under the title “Other devices” (not under the heading USB devices) is “LimeSDR-USB”. I click on “LimeSDR-USB” and get the message:
The drivers for this device are not installed (Code 28)
There are no compatible drivers for this device
To find a driver for this device click Update driver.
I click “Update driver” and select online searching. It starts searching online and after 10 minutes it has found nothing.
I then start USBview. A device is connected with an exclamation sign indicating something is not working. When I click on it I get the data from the enumeration and they are:
Device Descriptor:
bcdUSB: 0x0300
bDeviceClass: 0x00
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x09 (9)
idVendor: 0x1D50
idProduct: 0x6108
bcdDevice: 0x0000
iManufacturer: 0x01
iProduct: 0x02
iSerialNumber: 0x03
bNumConfigurations: 0x01
ConnectionStatus: DeviceConnected
Current Config Value: 0x00
Device Bus Speed: High
Device Address: 0x06
Open Pipes: 0
Configuration Descriptor:
wTotalLength: 0x0046
bNumInterfaces: 0x01
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0x80 (Bus Powered )
MaxPower: 0x32 (100 Ma)
Interface Descriptor:
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x04
bInterfaceClass: 0xFF
bInterfaceSubClass: 0x00
bInterfaceProtocol: 0x00
iInterface: 0x00
Endpoint Descriptor:
bEndpointAddress: 0x01 OUT
Transfer Type: Bulk
wMaxPacketSize: 0x0400 (1024)
bInterval: 0x00
Unknown Descriptor:
bDescriptorType: 0x30
bLength: 0x06
06 30 0F 00 00 00
bEndpointAddress: 0x81 IN
Transfer Type: Bulk
bInterval: 0x00
Unknown Descriptor:
bLength: 0x06
06 30 0F 00 00 00
bEndpointAddress: 0x0F OUT
Transfer Type: Bulk
bInterval: 0x00
Unknown Descriptor:
bLength: 0x06
06 30 00 00 00 00
bEndpointAddress: 0x8F IN
Transfer Type: Bulk
bInterval: 0x00
Unknown Descriptor:
bLength: 0x06
06 30 00 00 00 00
I appears to me that the USB enumeration fails, but I am not an expert in that. the parameters iManufacturer, iProduct and iSerialNumber look empty.
I have not tried to reload the FX3 software yet using the CyUSB suite. Do you have the software to reload the FX3 correctly in a form suitable for “dummies”?
Please, I need your help to either make my LimeSDR-USB work or conclude, that it is broken.
Regards,
Jorgen
