Multiple LimeSDR-USB failures
I installed Lime Suite GUI for testing and dev LimeSDR_USB boards on Windows Srv 2016, Windows 10, Raspberry Pi 3, Raspberry Pi 4 and Ubuntu19.04 about a year ago. I had some success but had to take on another project.
Now back to devving Lime SDR I have reinstalled and updated Lime Suite GUI on Windows and Rasp PI 4s and now Ububtu 20.04, and reinstalled Windows drivers, and board firmware and gateware.
The Win systems do not detect the boards so I’m not even getting out of the starting gate. The Linux sytems fail on loading the self-test.ini files.
Ideas, thoughts, advice ???
Hi @marisk,
Could you post LimeQuickTest log file here, please.
Attached are the png from terminal. What’s odd is that the media and name fields are reversed from the web instructions and the Soapy terminal output. Attached is also the Lime Suite Gui Connection string. I thought that LimeSDR-USB is USB 3.0
This is the log dump. I cannot get a log from the Windows (Srv and 10) because Windows does not detect the board. It’s interesting that exploring this issue I found many references to the problem that Windows USB stopped functioning correctly after the April 2020 updates.
11:18:44] ERROR: TransferPacket: Read failed (ret=0)
[11:19:06] INFO: Wr(64): 22 00 01 00 00 00 00 00 00 20 (00 x 54 times)
[11:19:06] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 ff fd (00 x 52 times)
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 cc 00 00 05 c9 00 00 05 c9 80 00 05 c8 00 00 05 c8 80 00 05 c5 00 00 05 c5 80 00 05 c3 00 00 05 c3 80 00 05 c2 00 00 05 a5 00 00 05 a4 00 00 05 9e 00 00 05 9d 00 00
[11:19:06] INFO: Rd(64): 21 01 0e 00 (00 x 60 times)
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 9a 00 00 05 99 00 00 05 93 00 00 05 91 00 00 05 90 00 00 05 8f 00 00 05 8a 00 00 05 88 00 00 05 87 00 00 05 c0 00 ff 05 86 00 00 05 85 00 00 05 83 00 00 05 81 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 82 00 00 05 80 00 00 05 66 00 00 05 64 00 00 05 63 00 00 05 62 00 00 03 25 00 00 03 21 00 00 03 1c 00 00 03 8f 00 00 05 60 00 00 03 18 00 00 02 d1 00 00 02 4b 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 14 00 00 03 11 00 00 05 52 00 00 03 17 00 00 03 08 00 00 05 a6 00 00 02 cb 00 00 03 05 00 00 03 a0 00 00 03 03 00 00 03 02 00 00 00 a6 00 07 02 97 00 00 01 0d 00 df
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 04 0f 23 24 03 06 00 00 04 8a 00 00 02 e7 00 00 02 e6 00 00 02 e5 00 00 02 ca 00 00 02 09 00 00 03 27 00 00 04 92 00 00 02 e2 00 00 02 8d 00 00 02 e1 00 00 04 a7 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 df 00 00 04 58 00 00 02 99 00 00 02 d7 00 00 01 0f 30 c6 05 94 00 00 03 1b 00 00 00 a0 65 65 02 08 01 70 04 d7 00 00 02 93 00 00 02 d2 00 00 02 c8 00 00 02 c5 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 23 00 00 02 d6 00 00 05 5c 00 00 02 83 00 00 03 84 00 00 03 89 00 00 04 c2 00 00 02 a4 00 00 05 9c 00 00 02 d4 00 00 02 a2 00 00 02 9f 00 00 02 9e 00 00 04 8b 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 9d 00 00 04 47 96 2f 04 9e 00 00 03 10 00 00 03 65 00 00 03 88 00 00 05 8e 00 00 03 81 00 00 05 12 00 00 00 8c 06 7b 03 9a 00 00 03 0e 00 00 01 1e 08 4b 03 46 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 98 00 00 00 25 01 01 04 d8 00 00 02 95 00 00 04 c8 00 00 02 8f 00 00 04 49 00 00 02 d3 00 00 04 9a 00 00 02 8e 00 00 04 4a 00 00 03 0b 00 00 02 a5 00 00 03 20 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 04 4c 00 00 02 90 00 00 02 8b 00 00 02 8a 00 00 05 25 00 00 02 89 00 00 00 a8 00 00 02 85 00 00 02 0b 40 00 02 0a 00 80 02 61 00 00 04 88 00 00 02 5f 00 00 03 09 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 0a 00 00 02 dc 00 00 03 61 00 00 05 50 00 00 02 9c 00 00 02 c0 00 00 04 02 07 ff 05 5f 00 00 02 59 00 00 00 a4 65 65 02 5d 00 00 00 82 80 01 02 57 00 00 03 50 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 a7 00 00 00 9b 65 65 01 02 31 80 03 55 00 00 01 01 78 00 02 c6 00 00 05 4e 00 00 00 a5 65 65 03 8e 00 00 05 9b 00 00 02 84 00 00 05 21 00 00 04 d0 00 00 04 a4 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 87 00 00 05 c1 00 00 02 c4 00 00 05 4d 00 00 02 50 00 00 04 05 00 00 05 5d 00 00 00 a2 65 65 02 91 00 00 04 ce 00 00 00 a1 65 65 05 57 00 00 00 81 00 00 02 04 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 00 9d 65 65 03 1d 00 00 00 9c 65 8c 02 03 10 00 03 a7 00 00 01 14 01 90 02 c2 00 00 00 9a 65 8c 01 0c 88 65 05 a1 00 00 04 5b 00 00 00 94 00 00 04 94 00 00 02 d9 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 5a 00 00 01 04 00 88 05 89 00 00 02 a3 00 00 01 17 18 b2 00 aa 00 00 02 c3 00 00 00 88 04 f0 01 1f 36 00 00 95 00 00 05 53 00 00 00 86 41 01 00 29 01 01 00 24 e4 e4
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 40 00 22 05 02 00 00 00 9f 65 8c 00 96 00 00 02 db 00 00 04 0a 10 01 05 c6 00 00 05 c6 80 00 01 18 01 8c 02 0c 80 00 00 a9 80 00 02 cd 00 00 00 23 55 50 03 1a 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 04 0e 00 00 01 22 03 3f 02 8c 00 00 03 22 00 00 02 c7 00 00 00 ae 00 00 05 8d 00 00 01 0e 00 00 05 07 00 00 03 01 00 00 05 42 00 00 03 90 00 00 00 22 07 df 03 58 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 14 00 00 00 a7 65 65 00 2b 00 13 02 c1 00 00 02 5e 00 00 00 92 00 01 02 cc 00 00 00 27 e4 e4 02 48 18 00 02 88 00 00 00 99 65 65 00 85 00 01 05 05 00 00 04 a2 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 56 00 00 00 28 01 01 02 94 00 00 00 8a 05 14 05 cb 1f 0f 04 a5 00 00 00 2e 00 00 05 24 00 00 00 84 04 00 00 26 01 01 00 2d 00 00 02 9a 00 00 03 0d 00 00 02 46 22 fc
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 dd 00 00 00 ad 03 ff 01 03 06 12 01 1a 30 02 03 12 00 00 05 51 00 00 01 09 00 80 02 07 00 00 05 22 00 00 05 0c 00 00 04 5e 00 00 01 13 03 c2 01 00 74 09 02 a0 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 01 15 00 09 01 16 81 80 01 1c a9 43 02 80 00 00 05 40 00 00 01 1d 80 00 02 44 29 aa 02 60 00 00 05 13 00 00 02 a6 00 00 02 de 00 00 02 55 00 00 03 9f 00 00 01 08 1d 8c
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 5a 00 00 05 84 00 00 01 21 33 10 01 24 00 00 05 17 00 00 02 c9 00 00 03 56 00 00 03 16 00 00 04 d6 00 00 00 2f 38 41 01 19 52 8c 02 06 00 00 03 4d 00 00 05 8b 00 00
[11:19:06] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 95 00 00 04 52 00 00 05 01 00 00 02 e0 00 00 02 01 07 ff 01 06 31 8c 00 8b 3f fe 03 94 00 00 02 02 07 ff 02 41 00 00 01 12 31 b9 02 42 01 99 04 81 00 00 03 62 00 00
[11:19:06] ERROR: TransferPacket: Read failed (ret=0)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 00 20 (00 x 54 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 ff ff (00 x 52 times)
[11:19:14] INFO: Wr(64): 21 00 01 00 00 00 00 00 00 20 ff fd (00 x 52 times)
[11:19:14] INFO: Rd(64): 21 01 01 00 (00 x 60 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 ff fd (00 x 52 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 00 06 (00 x 54 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 (00 x 60 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 04 03 (00 x 54 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 01 0d (00 x 54 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 00 9e (00 x 52 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 04 02 (00 x 54 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 07 ff (00 x 52 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 04 01 (00 x 54 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 01 0e (00 x 54 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 20 40 (00 x 52 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 03 (00 x 54 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 01 (00 x 54 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 02 (00 x 54 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 04 (00 x 54 times)
[11:19:14] INFO: Wr(64): 22 00 01 00 00 00 00 00 05 c0 (00 x 54 times)
[11:19:14] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 00 ff (00 x 52 times)
It is USB3 indeed.
Could you run LimeQuickTest and post log file here:
https://wiki.myriadrf.org/LimeQuickTest
Why is the connection string indicating USB 2.0. It is connected to a USB 3.0 port
Below is the Debug log data output :
[08:56:08] INFO: Wr(64): 22 00 01 00 00 00 00 00 00 20 (00 x 54 times)
[08:56:08] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 ff fd (00 x 52 times)
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 cc 00 00 05 c9 00 00 05 c9 80 00 05 c8 00 00 05 c8 80 00 05 c5 00 00 05 c5 80 00 05 c3 00 00 05 c3 80 00 05 c2 00 00 05 a5 00 00 05 a4 00 00 05 9e 00 00 05 9d 00 00
[08:56:08] INFO: Rd(64): 21 01 0e 00 (00 x 60 times)
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 9a 00 00 05 99 00 00 05 93 00 00 05 91 00 00 05 90 00 00 05 8f 00 00 05 8a 00 00 05 88 00 00 05 87 00 00 05 c0 00 ff 05 86 00 00 05 85 00 00 05 83 00 00 05 81 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 82 00 00 05 80 00 00 05 66 00 00 05 64 00 00 05 63 00 00 05 62 00 00 03 25 00 00 03 21 00 00 03 1c 00 00 03 8f 00 00 05 60 00 00 03 18 00 00 02 d1 00 00 02 4b 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 14 00 00 03 11 00 00 05 52 00 00 03 17 00 00 03 08 00 00 05 a6 00 00 02 cb 00 00 03 05 00 00 03 a0 00 00 03 03 00 00 03 02 00 00 00 a6 00 07 02 97 00 00 01 0d 00 df
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 04 0f 23 24 03 06 00 00 04 8a 00 00 02 e7 00 00 02 e6 00 00 02 e5 00 00 02 ca 00 00 02 09 00 00 03 27 00 00 04 92 00 00 02 e2 00 00 02 8d 00 00 02 e1 00 00 04 a7 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 df 00 00 04 58 00 00 02 99 00 00 02 d7 00 00 01 0f 30 c6 05 94 00 00 03 1b 00 00 00 a0 65 65 02 08 01 70 04 d7 00 00 02 93 00 00 02 d2 00 00 02 c8 00 00 02 c5 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 23 00 00 02 d6 00 00 05 5c 00 00 02 83 00 00 03 84 00 00 03 89 00 00 04 c2 00 00 02 a4 00 00 05 9c 00 00 02 d4 00 00 02 a2 00 00 02 9f 00 00 02 9e 00 00 04 8b 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 9d 00 00 04 47 96 2f 04 9e 00 00 03 10 00 00 03 65 00 00 03 88 00 00 05 8e 00 00 03 81 00 00 05 12 00 00 00 8c 06 7b 03 9a 00 00 03 0e 00 00 01 1e 08 4b 03 46 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 98 00 00 00 25 01 01 04 d8 00 00 02 95 00 00 04 c8 00 00 02 8f 00 00 04 49 00 00 02 d3 00 00 04 9a 00 00 02 8e 00 00 04 4a 00 00 03 0b 00 00 02 a5 00 00 03 20 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 04 4c 00 00 02 90 00 00 02 8b 00 00 02 8a 00 00 05 25 00 00 02 89 00 00 00 a8 00 00 02 85 00 00 02 0b 40 00 02 0a 00 80 02 61 00 00 04 88 00 00 02 5f 00 00 03 09 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 03 0a 00 00 02 dc 00 00 03 61 00 00 05 50 00 00 02 9c 00 00 02 c0 00 00 04 02 07 ff 05 5f 00 00 02 59 00 00 00 a4 65 65 02 5d 00 00 00 82 80 01 02 57 00 00 03 50 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 a7 00 00 00 9b 65 65 01 02 31 80 03 55 00 00 01 01 78 00 02 c6 00 00 05 4e 00 00 00 a5 65 65 03 8e 00 00 05 9b 00 00 02 84 00 00 05 21 00 00 04 d0 00 00 04 a4 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 87 00 00 05 c1 00 00 02 c4 00 00 05 4d 00 00 02 50 00 00 04 05 00 00 05 5d 00 00 00 a2 65 65 02 91 00 00 04 ce 00 00 00 a1 65 65 05 57 00 00 00 81 00 00 02 04 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 00 9d 65 65 03 1d 00 00 00 9c 65 8c 02 03 10 00 03 a7 00 00 01 14 01 90 02 c2 00 00 00 9a 65 8c 01 0c 88 65 05 a1 00 00 04 5b 00 00 00 94 00 00 04 94 00 00 02 d9 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 5a 00 00 01 04 00 88 05 89 00 00 02 a3 00 00 01 17 18 b2 00 aa 00 00 02 c3 00 00 00 88 04 f0 01 1f 36 00 00 95 00 00 05 53 00 00 00 86 41 01 00 29 01 01 00 24 e4 e4
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 40 00 22 05 02 00 00 00 9f 65 8c 00 96 00 00 02 db 00 00 04 0a 10 01 05 c6 00 00 05 c6 80 00 01 18 01 8c 02 0c 80 00 00 a9 80 00 02 cd 00 00 00 23 55 50 03 1a 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 04 0e 00 00 01 22 03 3f 02 8c 00 00 03 22 00 00 02 c7 00 00 00 ae 00 00 05 8d 00 00 01 0e 00 00 05 07 00 00 03 01 00 00 05 42 00 00 03 90 00 00 00 22 07 df 03 58 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 05 14 00 00 00 a7 65 65 00 2b 00 13 02 c1 00 00 02 5e 00 00 00 92 00 01 02 cc 00 00 00 27 e4 e4 02 48 18 00 02 88 00 00 00 99 65 65 00 85 00 01 05 05 00 00 04 a2 00 00
[08:56:08] INFO: Wr(64): 21 00 0e 00 00 00 00 00 02 56 00 00 00 28 01 01 02 94 00 00 00 8a 05 14 05 cb 1f 0f 04 a5 00 00 00 2e 00 00 05 24 00 00 00 84 04 00 00 26 01 01 00 2d 00 00 02 9a 00 00 03 0d 00 00 02 46 22 fc
[08:56:08] ERROR: TransferPacket: Read failed (ret=0)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 00 20 (00 x 54 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 ff ff (00 x 52 times)
[08:56:10] INFO: Wr(64): 21 00 01 00 00 00 00 00 00 20 ff fd (00 x 52 times)
[08:56:10] INFO: Rd(64): 21 01 01 00 (00 x 60 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 ff fd (00 x 52 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 00 06 (00 x 54 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 (00 x 60 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 05 c0 (00 x 54 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 00 ff (00 x 52 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 04 02 (00 x 54 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 07 ff (00 x 52 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 01 0d (00 x 54 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 00 9e (00 x 52 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 03 (00 x 54 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 01 (00 x 54 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 01 0e (00 x 54 times)
[08:56:10] INFO: Rd(64): 22 01 01 00 00 00 00 00 00 00 20 40 (00 x 52 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 04 (00 x 54 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 02 02 (00 x 54 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 04 01 (00 x 54 times)
[08:56:10] INFO: Wr(64): 22 00 01 00 00 00 00 00 04 03 (00 x 54 times)
I haven’t received any response to the ongoing issues that I’m experiencing with LimeSDR basics. Do I have a couple of hosed boards ?? Since following and executing the guidances and instructions on your websites end in exceptions or failures can I get functioning replacement boards. Or can I get a refund ?
Again:
The website will not log me in.
Here is the log
