Hi all,
I am trying to do a full sweep from 300MHz to 3GHz with my limeSDR mini, with an external cable connected from TX to RX.
I am using the SoapySDR API in Python.
I have noticed that, over time, I am loosing a lot of frequency points in my sweep. See pictures.
My guess is it is due to the heat. But even when the Lime is cooled down, my sweep still misses some frequencies. I can see on a spectrum analyzer that most of the lost frequencies are correctly generated, so it must be coming from the RX side.
Do you have any idea why ?
Which registers should I read to check if everything is fine ?
By setting the TX and RX PLL at the same frequency, the TDD mode should be enabled automatically, right ?
Note that I am not changing anything else (clicking default on LimeSuite before running my python script).
My code does the following:
import SoapySDR
from SoapySDR import * # SOAPY_SDR_ constants
import numpy as np
import matplotlib.pyplot as plt
freq_list = np.arange(300e6, 3e9, 10e6)
samp_rate = 20e6
tx_gain = 25
tx_bw= 5e6
rx_gain = 22
rx_bw= 5e6
# Create device instance
args = dict(driver="lime")
sdr = SoapySDR.Device(args)
# set sample rate
sdr.setSampleRate(SOAPY_SDR_TX, 0, samp_rate)
sdr.setSampleRate(SOAPY_SDR_RX, 0, samp_rate)
# set antenna
sdr.setAntenna(SOAPY_SDR_TX, 0, 'BAND2') # <2GHz
sdr.setAntenna(SOAPY_SDR_RX, 0, 'LNAW')
# set overall gain
sdr.setGain(SOAPY_SDR_TX, 0, tx_gain) # Set TX gain
sdr.setGain(SOAPY_SDR_RX, 0, rx_gain) # Set RX gain
# Set same RX and TX freq to have same PLL. Use of NCO to offset and be able to measure.
sdr.setFrequency(SOAPY_SDR_TX, 0, "RF", freq_list[0])
sleep(1)
sdr.setFrequency(SOAPY_SDR_RX, 0, "RF", freq_list[0])
sdr.setFrequency(SOAPY_SDR_TX, 0, "BB", 1e6)
sleep(1)
# set bw
sdr.setBandwidth(SOAPY_SDR_TX, 0, tx_bw) # TX BW
sdr.setBandwidth(SOAPY_SDR_TX, 0, rx_bw) # RX BW
# Set parameters to SDR and specify data format of complex floats 32-bits (CF32)
rxStream = sdr.setupStream(SOAPY_SDR_RX, SOAPY_SDR_CF32, [0])
sleep(1)
sdr.activateStream(rxStream, SOAPY_SDR_END_BURST)
# Create a re-usable buffer for rx samples
buff = np.array([0]*1024, np.complex64)
# Receive
sr = sdr.readStream(rxStream, [buff], len(buff))
sleep(0.5)
fig, ax = plt.subplots(figsize=(15, 10))
freq_axis = np.fft.fftfreq(len(buff), d=1/samp_rate)
fft = np.abs(np.fft.fft(buff)
plt.plot(freq_axis+freq_list[0]+1e6, fft)
plt.grid(True)
plt.ion()
ant_changed =0
indexes = np.arange(len(freq_list)-1)+1
for i in indexes:
if freq_list[i] > 2e9 and ant_changed == 0:
ant_changed = 1
sdr.setAntenna(SOAPY_SDR_RX, 0, 'LNAH')
sdr.setAntenna(SOAPY_SDR_TX, 0, 'BAND1')
print 'Antenna changed'
print("current freq:{} MHz".format(freq_list[i]/1e6))
sdr.setFrequency(SOAPY_SDR_TX, 0, "RF", freq_list[i])
sleep(1)
sdr.setFrequency(SOAPY_SDR_RX, 0, "RF", freq_list[i])
sleep(1)
sleep(0.5)
fft = np.abs(np.fft.fft(buff))
plt.plot(freq_axis+freq_list[i]+1e6, fft)
plt.show()
Thank you in advance for your help.
first one is when hot, second when cold.
