->Start time: Sun Feb 10 08:39:44 2019
Gateware version mismatch!
Expected gateware version 2, revision 17
Lime Suite - Myriad-RF Wiki
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009062A00CE2B1A, index=0
Serial Number: 0009062A00CE2B1A
->FX3 GPIF clock test
Test results: 1; 0; 0 - PASSED
->Si5351C test
CLK0: 2 / 17554 - FAILED
CLK1: 2 / 17554 - FAILED
CLK2: 2 / 17554 - FAILED
CLK3: 2 / 17554 - FAILED
CLK4: 2 / 17554 - FAILED
CLK5: 2 / 17554 - FAILED
CLK6: 2 / 17554 - FAILED
FAILED
->ADF4002 Test
Result: 0 - FAILED
FAILED
Results : 4 (min); 4 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: 11 05 11 11 05 11 03
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencySXT(1250 MHz) - cannot deliver frequency
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.06 seconds
->Start time: Sun Feb 10 08:42:35 2019
But found version 2, revision 18
Test results: 27410; 31166; 34922 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112933 (min); 5113066 (max) - PASSED
->Clock Network Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-13.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.9 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-13.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-19.2 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.9 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-13.4 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 5.74 seconds
