I have a LimeSDR Mini purchased from Mouser, still within warranty. I have had problems since I first purchased it but have finally worked out what is going wrong:
When it is cold (room temperature), and I am trying to set a receive frequency of 437 MHz, I get the following error from LMS_Init:
SetFrequencySXT(1240.01 MHz) - cannot deliver frequency
Once the LimeSDR warms up, it works OK, so it does not seem to be an application problem. I have swapped out with a friend’s LimeSDR Mini on the same hardware and that works perfectly, cold or hot. USB supply voltage measured on the LimeSDR Mini edge connectors is 5.1v.
LimeQuickTest when cold (and nothing connected to the SMAs) seems to suggest the same fault:
pi@raspberrypi:~ $ LimeQuickTest
->Start time: Wed Mar 30 12:21:46 2022
->LimeSuite version: 20.10.0-unknown
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D750851EC1757, HW=3, GW=1.30
Serial Number: 1D750851EC1757
Chip temperature: 20 C
->REF clock test
Test results: 54542; 2203; 15400 - PASSED
Results : 6711006 (min); 6711162 (max) - PASSED
->Clock Network Test PASSED
->Read data: 15 05 18 15 05 18 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
SetFrequencySXT(1005 MHz) - cannot deliver frequency
->Run Tests (TX_1 -> LNA_H):
SetFrequencySXT(2105 MHz) - cannot deliver frequency
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.39 seconds
Please could you authorise an RMA so that I can get a refund and wait for a LimeSDR Mini V2?
Thanks
Gareth
