I’m using a limesdr mini, updated with the last LimeUtil on my Archlinux distribution:
Version information:
Library version: v18.06.0-18.06.0
Build timestamp: 2018-09-30
Interface version: v2018.6.0
Binary interface: 18.06-1
The quick test is passing:
remy@StateOfTheArt ~ % LimeQuickTest
->Start time: Sun Sep 30 18:49:31 2018
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D40EC646BF755
Serial Number: 1D40EC646BF755
->REF clock test
Test results: 39360; 52557; 218 - PASSED
Results : 6711063 (min); 6711223 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 06 1C 12 06 1C 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-14.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.2 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.63 seconds
Yet, using gr-limesdr, I’m often faced with this kind of errors (see attached screenshot).
INFO: device_handler::set_chip_mode(): SISO mode set for device number 0.
INFO: device_handler::set_rf_freq(): RF frequency set [RX]: 868 MHz.
SetPllFrequency: error configuring phase
ERROR:
What am I doing wrong?
