I received my LimeSDR mini one week ago, however I’m not able to make it work properly.
Indeed, on “high” frequencies I always get the error “SetPllFrequency: error configuring phase” even though I installed newest version of LimeSuite from source.
See LimeQuickTest result below:
->Start time: Sat Dec 8 10:07:03 2018
->Device: LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D424C38BA0251
Warning: USB3 not available
Serial Number: 1D424C38BA0251
->REF clock test
Test results: 64146; 11807; 25004 - PASSED
Results : 6711097 (min); 6711248 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 1A 12 07 1A 03
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.25 seconds
Yes, I am running the board on a RaspberryPi 3 with USB 2.0 only, and don’t have USB 3.0 to test yet (waiting on an ODROID-XU4 delivery).
So, first of all, could that be a limitation due to USB?
Other details:
LimeSuite information summary
Version information:
Library version: v18.10.0-1
Build timestamp: 2018-12-07
Interface version: v2018.10.0
Binary interface: 18.10-1
System resources:
Installation root: /usr
User home directory: /home/pi
App data directory: /home/pi/.local/share/LimeSuite
Config directory: /home/pi/.limesuite
Image search paths:
- /home/pi/.local/share/LimeSuite/images
- /usr/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
Gateware installed currently is version 1.27, matching my LimeSuite installation.
I did some tests with LimeSuiteGUI, reading some other topics, and here are the results:
Calculate SXR 1200 MHz: PASSED
Calculate SXT 1250 MHz: PASSED
Calculate CLKGEN 10MHz with OV_CLKL at 1: PASSED
Calculate CLKGEN 30MHw with OV_CLKL at 1: FAILED
Calculate CLKGEN 30MHz with OV_CLKL at 8: PASSED (fails at 40MHz)
If Auto phase is disabled I don’t get the error.
Also pushing the “Default” button says Load Default Failed, with the same PLL error in the logs.
Please note that even though I get this error I’m able to transmit at certain frequencies.
If I take the FM_Transmitter example provided with gr-limesdr as is, it works, see below:
LimeSuite Sink (TX) info
Connecting to device
Devices found: 1
Device list:
Nr.:|0|device:|LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D424C38BA0251
Device number 0 from the list is used.
Reference clock 40.00 MHz
INFO: device_handler::set_chip_mode(): SISO mode set for device number 0.
INFO: device_handler::set_rf_freq(): RF frequency set [TX]: 443.094 MHz.
INFO: device_handler::set_samp_rate(): set sampling rate: 0.48 MS/s.
Filter calibrated. Filter order-4th, filter bandwidth set to 5 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
TX LPF configured
INFO: device_handler::set_analog_filter(): Configured bandwidth: 5 MHz.
INFO: device_handler::set_digital_filter(): digital filter channel 0 [TX]: 0.1 MHz.
INFO: device_handler::set_antenna(): channel 0 antenna set [TX]: BAND1.
INFO: device_handler::set_gain(): set gain [TX]: 36 dB.
Tx calibration finished
INFO: device_handler::calibrate(): INFO: sink_impl::init_stream(): sink channel 0 (device nr. 0) stream setup done.
INFO: device_handler::close_device(): Disconnected from device number 0.
on the RX side I get the appropriate RF (please note the PLL error).
Has anyone any idea on why I’m getting this error? @Zack, I see you have been pretty active on the posts related to these kind of issues, so please allow me to tag you.
Regards,
Yanik
