Hello everyone,
Recently I am getting this error from the gnuradio. every driver and gnuradio was installed from the source. Any ideas?
Best
Hello everyone,
Best
@IGnasJ can you advise, please.
I am getting same error too
We are checking it.
Just to add a “me too”.
Built from latest GIT and latest Firmware/Gateware.
I’m running two channels, at 5.0Msps.
It might be about gateware version 15 when I downgraded to 12 It was fine and just getting warning: upgrade the gateware version to 15
@Zack Any update on this? I am seeing it as well.
EDIT:
I see this is version 16 as well when i try and load self_test.ini
It is fixed in the latest gateware (ver. 2.16).
@zack that is the version I was using.
Hi @btashton,
Update the LimeSuite too.
This is the commit that I built off of.
Maybe there is a hardware issue with my LimeSDR that this is bringing to light? https://github.com/myriadrf/LimeSuite/commit/67dcef198dc8ec79116085595bb34938b182dfdd
@Zack I’m starting to think there is a hardware issue here and this new firmware is just highlighting the clock issue.
Attached is the test signal from the quick test. It looks off by about 200MHz. Any thoughts?
Looking at the REF CLK out, there is a small signal at the expected 30.72MHz, but a much larger signal at 27MHz
Hi @btashton,
Could you share more information about your setup, please. I assume this is LimeSDR-USB board and you run LimeSuiteGUI and self_test.ini configuration file (it looks like you don’t, while TX frequency in this file is set to 2.1GHz). Do you follow Quick Test procedure step by step? Do you change SXT frequency? Do you push “Calculate” button in SXT tab?
First of all, you have to solder R151 if you want to get REF_CLK_OUT signal out, while this resistor is no fit by default. This is an excerpt from schematic:
This is where R151 is located on PCB:
27MHz is used as a reference clock for SDRAMs hence you pick up it too.
Running LimeSuite that I just built from master I loaded the latest firmware:
programming: completed (/home/bashton/.local/share/LimeSuite/images/18.04/LimeSDR-USB_HW_1.4_r2.16.rbf)
With this firmware I cannot load the setf_test.ini file it show this and then a dialog saying failed to open the file.
[17:37:22] DEBUG: Estimated reference clock 30.6586 MHz
[17:37:22] INFO: Reference clock 30.72 MHz
[17:37:22] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.16 Ref Clk: 30.72 MHz
[17:37:28] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 3
[17:37:28] DEBUG: VCO 1966.08 MHz, RefClk 30.72 MHz
[17:37:28] DEBUG: csw 57; interval [54, 60]
[17:37:28] DEBUG: M=252, N=6, Fvco=1290.240 MHz
[17:37:28] DEBUG: M=252, N=12, Fvco=1290.240 MHz
[17:37:28] ERROR: SetPllFrequency: error configuring phase
The image I took above was using the gateware 2.12, but I had been playing with Part 5 of this LimeSDR-USB Quick Test - Myriad-RF Wiki which sets it to 800MHz
Here are the logs when I try to run the first section of the Quick test:
[17:43:22] WARNING: Gateware version mismatch!
Expected gateware version 2, revision 16
But found version 2, revision 12
Lime Suite - Myriad-RF Wiki
[17:43:22] DEBUG: Estimated reference clock 30.6586 MHz
[17:43:22] INFO: Reference clock 30.72 MHz
[17:43:22] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.12 Ref Clk: 30.72 MHz
[17:43:29] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 3
[17:43:29] DEBUG: VCO 1966.08 MHz, RefClk 30.72 MHz
[17:43:29] DEBUG: csw 59; interval [56, 62]
[17:43:29] DEBUG: M=252, N=6, Fvco=1290.240 MHz
[17:43:29] DEBUG: M=252, N=12, Fvco=1290.240 MHz
[17:43:46] DEBUG: INT 132, FRAC 753664, DIV_LOCH 0, EN_DIV2_DIVPROG 0
[17:43:46] DEBUG: VCO 4200.00 MHz, RefClk 30.72 MHz
[17:43:46] DEBUG: ICT_VCO: 255
[17:43:46] DEBUG: csw=64 cmphl=0
[17:43:46] DEBUG: csw=96 cmphl=0
[17:43:46] DEBUG: csw=112 cmphl=3
[17:43:46] DEBUG: csw=104 cmphl=3
[17:43:46] DEBUG: csw=100 cmphl=2
[17:43:46] DEBUG: csw=102 cmphl=2
[17:43:46] DEBUG: csw=103 cmphl=3
[17:43:46] DEBUG: Failed to lock
[17:43:46] DEBUG: csw=192 cmphl=3
[17:43:46] DEBUG: csw=160 cmphl=3
[17:43:46] DEBUG: csw=144 cmphl=3
[17:43:46] DEBUG: csw=136 cmphl=3
[17:43:46] DEBUG: csw=132 cmphl=3
[17:43:46] DEBUG: csw=130 cmphl=3
[17:43:46] DEBUG: csw=129 cmphl=3
[17:43:46] DEBUG: cmphl=2
[17:43:46] DEBUG: VCOL : csw=99 tune ok
[17:43:46] DEBUG: TuneVCO(SXT) - VCO too high
[17:43:46] DEBUG: VCOM : csw=0 tune fail
[17:43:46] DEBUG: VCOH : csw=0 tune fail
[17:43:46] DEBUG: Selected: VCOL
[17:43:46] INFO: SXT frequency set to 2100.000000 MHz
[17:43:53] DEBUG: ICT_VCO: 255
[17:43:53] DEBUG: csw=64 cmphl=0
[17:43:53] DEBUG: csw=96 cmphl=0
[17:43:53] DEBUG: csw=112 cmphl=3
[17:43:53] DEBUG: csw=104 cmphl=3
[17:43:53] DEBUG: csw=100 cmphl=2
[17:43:53] DEBUG: csw=102 cmphl=2
[17:43:53] DEBUG: csw=103 cmphl=3
[17:43:53] DEBUG: Failed to lock
[17:43:53] DEBUG: csw=192 cmphl=3
[17:43:53] DEBUG: csw=160 cmphl=3
[17:43:53] DEBUG: csw=144 cmphl=3
[17:43:53] DEBUG: csw=136 cmphl=3
[17:43:53] DEBUG: csw=132 cmphl=3
[17:43:53] DEBUG: csw=130 cmphl=3
[17:43:53] DEBUG: csw=129 cmphl=3
[17:43:53] DEBUG: cmphl=2
[17:44:05] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 3
[17:44:05] DEBUG: VCO 1966.08 MHz, RefClk 30.72 MHz
[17:44:05] DEBUG: csw 59; interval [56, 62]
[17:44:05] DEBUG: M=252, N=6, Fvco=1290.240 MHz
[17:44:05] DEBUG: M=252, N=12, Fvco=1290.240 MHz
[17:44:05] INFO: CGEN frequency set to 245.760000 MHz
[17:44:06] DEBUG: csw 59; interval [56, 62]
[17:44:06] DEBUG: M=252, N=6, Fvco=1290.240 MHz
[17:44:06] DEBUG: M=252, N=12, Fvco=1290.240 MHz
[17:44:49] DEBUG: INT 113, FRAC 196608, DIV_LOCH 3, EN_DIV2_DIVPROG 1
[17:44:49] DEBUG: VCO 7200.00 MHz, RefClk 30.72 MHz
[17:44:49] DEBUG: ICT_VCO: 255
[17:44:49] DEBUG: TuneVCO(SXR) - VCO too low
[17:44:49] DEBUG: VCOL : csw=0 tune fail
[17:44:49] DEBUG: VCOM : csw=0 tune fail
[17:44:49] DEBUG: csw=64 cmphl=0
[17:44:49] DEBUG: csw=96 cmphl=0
[17:44:49] DEBUG: csw=112 cmphl=0
[17:44:49] DEBUG: csw=120 cmphl=0
[17:44:49] DEBUG: csw=124 cmphl=0
[17:44:49] DEBUG: csw=126 cmphl=0
[17:44:49] DEBUG: csw=127 cmphl=0
[17:44:49] DEBUG: Failed to lock
[17:44:49] DEBUG: csw=192 cmphl=3
[17:44:49] DEBUG: csw=160 cmphl=2
[17:44:49] DEBUG: csw=176 cmphl=3
[17:44:49] DEBUG: csw=168 cmphl=2
[17:44:49] DEBUG: csw=172 cmphl=2
[17:44:49] DEBUG: csw=174 cmphl=2
[17:44:49] DEBUG: csw=175 cmphl=2
[17:44:49] DEBUG: CSW: lowest=160, highest=175, selected=167
[17:44:49] DEBUG: cmphl=2
[17:44:49] DEBUG: VCOH : csw=167 tune ok
[17:44:49] DEBUG: Selected: VCOH
[17:44:49] DEBUG: INT 113, FRAC 458752, DIV_LOCH 3, EN_DIV2_DIVPROG 1
[17:44:49] DEBUG: VCO 7215.36 MHz, RefClk 30.72 MHz
[17:44:49] DEBUG: TuneVCO(SXT) - VCO too low
[17:44:49] DEBUG: csw=160 cmphl=0
[17:44:49] DEBUG: csw=176 cmphl=2
[17:44:49] DEBUG: csw=184 cmphl=3
[17:44:49] DEBUG: csw=180 cmphl=3
[17:44:49] DEBUG: csw=178 cmphl=2
[17:44:49] DEBUG: csw=179 cmphl=3
[17:44:49] DEBUG: VCOH : csw=170 tune ok
[17:44:49] DEBUG: INT 113, FRAC 720896, DIV_LOCH 3, EN_DIV2_DIVPROG 1
[17:44:49] DEBUG: VCO 7230.72 MHz, RefClk 30.72 MHz
[17:44:49] DEBUG: csw=180 cmphl=2
[17:44:49] DEBUG: csw=182 cmphl=3
[17:44:49] DEBUG: csw=181 cmphl=2
[17:44:49] DEBUG: CSW: lowest=166, highest=181, selected=173
[17:44:49] DEBUG: VCOH : csw=173 tune ok
[17:44:49] DEBUG: INT 132, FRAC 819200, DIV_LOCH 0, EN_DIV2_DIVPROG 0
[17:44:49] DEBUG: VCO 4201.92 MHz, RefClk 30.72 MHz
[17:44:49] DEBUG: csw=112 cmphl=3
[17:44:49] DEBUG: csw=104 cmphl=3
[17:44:49] DEBUG: csw=100 cmphl=2
[17:44:49] DEBUG: csw=102 cmphl=2
[17:44:49] DEBUG: csw=103 cmphl=2
[17:44:49] DEBUG: CSW: lowest=97, highest=103, selected=100
[17:44:49] DEBUG: csw=160 cmphl=3
[17:44:49] DEBUG: csw=144 cmphl=3
[17:44:49] DEBUG: csw=136 cmphl=3
[17:44:49] DEBUG: csw=132 cmphl=3
[17:44:49] DEBUG: csw=130 cmphl=3
[17:44:49] DEBUG: csw=129 cmphl=3
[17:44:49] DEBUG: VCOL : csw=100 tune ok
[17:44:49] DEBUG: TuneVCO(SXT) - VCO too high
[17:44:49] DEBUG: VCOH : csw=0 tune fail
[17:44:49] DEBUG: Selected: VCOL
And the FFT which looks very noisy to me.
Hi @btashton,
Try to execute LimeSuiteGUI with admin rights.
@Zack
I ran this under Linux. It has no permission issue loading the file. The file loads fine when I have the old gateware on the board.
Hi @btashton,
Could you try this, please:
@Zack It is not a permissions issue. It clearly loads the file, but fails to configure the hardware.
I just pulled the latest code from master and ran though the test anyway and both clock calculations failed:
[14:26:08] INFO: Disconnected control port
[14:26:20] INFO: Reference clock 30.72 MHz
[14:26:20] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.16 Ref Clk: 30.72 MHz
[14:26:30] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 3
[14:26:30] DEBUG: VCO 1966.08 MHz, RefClk 30.72 MHz
[14:26:30] DEBUG: csw 57; interval [54, 60]
[14:26:30] DEBUG: M=252, N=6, Fvco=1290.240 MHz
[14:26:30] DEBUG: M=252, N=12, Fvco=1290.240 MHz
[14:26:30] ERROR: SetPllFrequency: error configuring phase
[14:27:54] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 3
[14:27:54] DEBUG: VCO 1966.08 MHz, RefClk 30.72 MHz
[14:27:54] DEBUG: csw 58; interval [55, 61]
[14:27:54] DEBUG: M=252, N=6, Fvco=1290.240 MHz
[14:27:54] DEBUG: M=252, N=12, Fvco=1290.240 MHz
[14:27:54] ERROR: SetPllFrequency: error configuring phase
[14:27:57] INFO: CGEN frequency set to 245.760000 MHz
[14:28:13] DEBUG: INT 77, FRAC 131072, DIV_OUTCH_CGEN 14
[14:28:13] DEBUG: VCO 2400.00 MHz, RefClk 30.72 MHz
[14:28:13] DEBUG: csw 172; interval [170, 175]
[14:28:13] DEBUG: M=130, N=1, Fvco=1300.000 MHz
[14:28:13] DEBUG: M=195, N=3, Fvco=1300.000 MHz
[14:28:13] ERROR: SetPllFrequency: error configuring phase
[14:28:15] INFO: CGEN frequency set to 80.000000 MHz
@Zack I also just tried installing the power header to power the board via an external power supply and I got the same results. The LEDs are as follows:
This seems to be the normal status.
