I’ve run the LimeQuickTest on a 15sec loop immediately after boot, see log below. Seems to take just over a minute after boot to fail the test.
For what it’s worth, there seems to have been a change in the devices behavior from 19.01 - > 19.04. After upgrading firmware, the device can now calibrate SXR and SXT properly at all the frequencies I’ve tried so far. Could be attributed to commit 6feb479 where they changed the gain to meet tune.
Anyways, hope these logs help,
Stew
pi@raspberrypi:~ $ while sleep 15; do LimeQuickTest; done
->Start time: Sat May 18 21:17:43 2019
->REF clock test
Test results: 21760; 40981; 60203 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5154065 (min); 5154089 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 03 08 13 03 08 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Testing using internal LMS7002M loopback
->Run Tests (TX_1-> LNA_H):
CH0 (SXR=1800.0MHz, SXT=1802.0MHz): Result:(-11.9 dBFS, 2.00 MHz) - PASSED
->Run Tests (TX_2 -> LNA_L):
CH0 (SXR=750.0MHz, SXT=752.0MHz): Result:(-12.2 dBFS, 2.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 3.35 seconds
->Start time: Sat May 18 21:18:02 2019
->REF clock test
Test results: 20599; 39821; 59042 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5154068 (min); 5154091 (max) - PASSED
CH0 (SXR=1800.0MHz, SXT=1802.0MHz): Result:(-12.3 dBFS, 2.00 MHz) - PASSED
CH0 (SXR=750.0MHz, SXT=752.0MHz): Result:(-12.5 dBFS, 2.00 MHz) - PASSED
Elapsed time: 3.32 seconds
->Start time: Sat May 18 21:18:21 2019
->REF clock test
Test results: 11860; 31082; 50303 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5154070 (min); 5154094 (max) - PASSED
CH0 (SXR=1800.0MHz, SXT=1802.0MHz): Result:(-12.5 dBFS, 2.00 MHz) - PASSED
CH0 (SXR=750.0MHz, SXT=752.0MHz): Result:(-12.6 dBFS, 2.00 MHz) - PASSED
Elapsed time: 3.31 seconds
->Start time: Sat May 18 21:18:39 2019
->REF clock test
Test results: 1227; 20448; 39670 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5154072 (min); 5154096 (max) - PASSED
CH0 (SXR=1800.0MHz, SXT=1802.0MHz): Result:(-12.6 dBFS, 2.00 MHz) - PASSED
CH0 (SXR=750.0MHz, SXT=752.0MHz): Result:(-12.7 dBFS, 2.00 MHz) - PASSED
->Start time: Sat May 18 21:18:58 2019
->REF clock test
Test results: 63708; 17393; 36615 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5154073 (min); 5154097 (max) - PASSED
CH0 (SXR=1800.0MHz, SXT=1802.0MHz): Result:(-12.7 dBFS, 2.00 MHz) - PASSED
SetFrequencySXT(752 MHz) - cannot deliver frequency
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.21 seconds
