I’ve had my lime mini for a couple of months. All I’ve done with it so far is some basic ISM receiving.
Today I updated the firmware using LimeUtil, and afterwards I decided to run LimeQuickTest. Should I be worried about the failed loopback test?
LimeQuickTest
->Start time: Thu Oct 11 21:15:04 2018->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D40E150A83D23
Serial Number: 1D40E150A83D23[ Clock Network Test ]
->REF clock test
Test results: 48560; 61757; 9418 - PASSED
Results : 6711043 (min); 6711203 (max) - PASSED
->Clock Network Test PASSED[ FPGA EEPROM Test ]
->Read data: 12 06 1B 12 06 1B 02
->FPGA EEPROM Test PASSED[ LMS7002M Test ]
->LMS7002M Test PASSED[ RF Loopback Test ]
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-27.4 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-15.3 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED=> Board tests FAILED <=
Elapsed time: 2.52 seconds
