I am using Ubuntu 18.04 with the latest version:
But the LMS7002M Test failt sometimes and the RF loopback failt every time
SoapySDRUtil --info
Lib Version: v0.7.1-myriadrf1~ubuntu18.04
API Version: v0.7.1
ABI Version: v0.7
Install root: /usr
Search path: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.7
Search path: /usr/local/lib/x86_64-linux-gnu/SoapySDR/modules0.7 (missing)
Search path: /usr/local/lib/SoapySDR/modules0.7 (missing)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.7/libHackRFSupport.so (0.3.3)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.7/libLMS7Support.so (19.01.0)
Available factories… hackrf, lime
Available converters…
- CS32 -> [CS32]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- S32 -> [S32]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
fs@nouveau:~$ SoapySDRUtil --find=“driver=lime”
Found device 0
addr = 24607:1027
driver = lime
label = LimeSDR Mini [USB 3.0] 1D3A0AE6BE4F2E
media = USB 3.0
module = FT601
name = LimeSDR Mini
serial = 1D3A0AE6BE4F2E
fs@nouveau:~$ Lime
LimeQuickTest LimeSuiteGUI LimeUtil
fs@nouveau:~$ LimeQuickTest
->Start time: Sat Mar 2 06:52:28 2019
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3A0AE6BE4F2E
Serial Number: 1D3A0AE6BE4F2E
->REF clock test
Test results: 39807; 53004; 665 - PASSED
Results : 6711007 (min); 6711166 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 02 08 12 02 08 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
SetPllFrequency: timeout, busy bit is still 1
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 8.09 seconds
Sometimes I get this
RegistersTest() failed
->LMS7002M Test FAILED
What can be the cause?
I am using a HP Z400, PCI USB3 card, the Limeminisdr is connected to an USB 3,0 HUB, I change this HUB, the error is the same.
