Hi guys,
I’m trying to use the OAI code with the LimeSDR-USB board. The eNB works well with the USRP.
When I use the LimeSDR instead of the USRP, I get some errors. It seems that the main problem is with the
rfdevice timing drift of some samples.
Another error is:
“[S1AP][E][s1ap_eNB_task] Failed to find ue contextassociated with eNB ue s1ap id: 420141”
It’s noteworthy to point that the LimeQuickTest has run successfully.
Here is the output log file: http://www.mediafire.com/file/qg6cws5mxb3a302/Output.txt/file
Here is the WireShark output for the connection between eNB and the core: http://www.mediafire.com/file/ieep7miweelabpx/WireShark_Output.pcapng/file
Here is the eNB configuration file: http://www.mediafire.com/file/hlj66q02cx0sk9x/eNB.conf/file
Here is the LimeSDR configuration file:http://www.mediafire.com/file/hlj66q02cx0sk9x/eNB.conf/file
Any kind of help would be thoroughly appreciated…
