Hi, I am trying to build the OpenAirInterface (OAI) eNodeB with LimeSDR. I am using the configuration file ‘~/openairinterface/targets/PROJECTS/GENERIC-LTE-EPC/CONF/enb.band7.tm1.25PRB.lmssdr.conf’ with my EPC and eNodeB specific configurations. During the building phase the EPC can read the eNodeB but the building fails eventually. I am getting warnings about ‘Firmware version mismatch!’ and ‘Gateware version mismatch!’. And the compilation exists with an error ‘[PHY][E]rx_rf: Asked for 7680 samples, got 0 from USRP’.
Am I getting the error for the firmware upgrade issue or there is something else that I might be missing? I greatly appreciate your help on this.
The compilation log is as follows:
root@ovpnclt:~/openairinterface5g/cmake_targets/lte_build_oai/build# sudo ./lte-softmodem -O …/…/…/targets/PROJECTS/GENERIC-LTE-EPC/CONF/cengn.enb.band7.tm1.25PRB.lmssdr.conf --rf-config-file …/…/…/targets/ARCH/LMSSDR/LimeSDR_above_1p8GHz.ini
/dev/cpu_dma_latency set to 0us
log init done
num component carrier 1
WARNING: setting ‘gtpu_log_level’ not found in configuration file
WARNING: setting ‘gtpu_log_verbosity’ not found in configuration file
WARNING: setting ‘udp_log_level’ not found in configuration file
WARNING: setting ‘udp_log_verbosity’ not found in configuration file
WARNING: setting ‘osa_log_level’ not found in configuration file
WARNING: setting ‘osa_log_verbosity’ not found in configuration file
ENB CONFIG FILE CONTENT LOADED (TBC):
ENB CONFIG for instance 0:
eNB name: eNB_Eurecom_LTEBox:
eNB ID: 42:
Cell type: CELL_MACRO_ENB:
TAC: 12594:
MCC: 1:
MNC: 01:
node_function for CC 0: eNodeB_3GPP:
node_timing for CC 0: synch_to_ext_device:
node_synch_ref for CC 0: 0:
eutra band for CC 0: 7:
downlink freq for CC 0: 2680000000:
uplink freq offset for CC 0: -120000000:
Cell ID for CC 0: 0:
N_RB_DL for CC 0: 25:
nb_antenna_ports for CC 0: 1:
nb_antennas_tx for CC 0: 1:
nb_antennas_rx for CC 0: 1:
rach_numberOfRA_Preambles for CC 0: 15:
rach_preamblesGroupAConfig for CC 0: 0:
rach_powerRampingStep for CC 0: 2:
rach_preambleInitialReceivedTargetPower for CC 0: 8:
rach_preambleTransMax for CC 0: 6:
rach_raResponseWindowSize for CC 0: 7:
rach_macContentionResolutionTimer for CC 0: 5:
rach_maxHARQ_Msg3Tx for CC 0: 4:
bcch_modificationPeriodCoeff for CC 0: 0:
pcch_defaultPagingCycle for CC 0: 2:
pcch_nB for CC 0: 2:
prach_root for CC 0: 0:
prach_config_index for CC 0: 0:
prach_high_speed for CC 0: 0:
prach_zero_correlation for CC 0: 1:
prach_freq_offset for CC 0: 2:
pdsch_referenceSignalPower for CC 0: -34:
pdsch_p_b for CC 0: 0:
pusch_n_SB for CC 0: 1:
pusch_hoppingMode for CC 0: 0:
pusch_hoppingOffset for CC 0: 0:
pusch_enable64QAM for CC 0: 0:
pusch_groupHoppingEnabled for CC 0: 1:
pusch_groupAssignment for CC 0: 0:
pusch_sequenceHoppingEnabled for CC 0: 0:
pusch_nDMRS1 for CC 0: 1:
pucch_delta_shift for CC 0: 0:
pucch_nRB_CQI for CC 0: 1:
pucch_nCS_AN for CC 0: 0:
srs_enable for CC 0: 0:
pusch_p0_Nominal for CC 0: -96:
pucch_p0_Nominal for CC 0: -104:
pusch_alpha for CC 0: 7:
pucch_deltaF_Format1 for CC 0: 2:
pucch_deltaF_Format1b for CC 0: 1:
pucch_deltaF_Format2 for CC 0: 1:
pucch_deltaF_Format2a for CC 0: 1:
pucch_deltaF_Format2b for CC 0: 1:
msg3_delta_Preamble for CC 0: 6:
ul_CyclicPrefixLength for CC 0: 0:
ue_TimersAndConstants_t300 for CC 0: 5:
ue_TimersAndConstants_t301 for CC 0: 5:
ue_TimersAndConstants_t310 for CC 0: 5:
ue_TimersAndConstants_n310 for CC 0: 7:
ue_TimersAndConstants_t311 for CC 0: 3:
ue_TimersAndConstants_n311 for CC 0: 0:
ue_TransmissionMode for CC 0: 0:
Global log level: info
HW log level: info
PHY log level: info
MAC log level: info
RLC log level: info
PDCP log level: info
RRC log level: info
UDP log level: info
GTP log level: info
OSA log level: info
Downlink frequency/ uplink offset of CC_id 0 set to 2680000000/-120000000
configuring for eNB
CPU Freq is 1.700107
reported resolution = 1 ns
[HW][I]Version: Branch: develop Abrev. Hash: 9bef36f Date: Mon May 22 11:41:14 2017 +0200
[PHY][I]Initializing frame parms for N_RB_DL 25, Ncp 0, osf 1
lte_parms.c: Setting N_RB_DL to 25, ofdm_symbol_size 512
[PHY][I][eNB 0] Initializing DL_FRAME_PARMS : N_RB_DL 25, PHICH Resource 1, PHICH Duration 0
[openair][LTE_PHY][INIT] common_vars->txdataF[0][0] = 0x7f109e5ba040 (286720 bytes)
[openair][LTE_PHY][INIT] common_vars->txdataF[0][5] = 0x7f109af39040 (286720 bytes)
[openair][LTE_PHY][INIT] common_vars->txdata[0][0] = 0x7f109aeed040 (307200 bytes)
[openair][LTE_PHY][INIT] common_vars->rxdata[0][0] = 0x7f109aea1040 (307200 bytes)
[openair][LTE_PHY][INIT] common_vars->rxdata_7_5kHz[0][0] = 0x1645b0e0 (61440 bytes)
[openair][LTE_PHY][INIT] prach_vars->rxsigF[0] = 0x16825e40
[openair][LTE_PHY][INIT] prach_vars->prach_ifft[0] = 0x1682bea0
[PHY][I]init eNB: Node Function 0
[PHY][I]init eNB: Nid_cell 0
[PHY][I]init eNB: frame_type 0,tdd_config 3
[PHY][I]init eNB: number of ue max 16 number of enb max 1 number of harq pid max 8
[PHY][I]init eNB: N_RB_DL 25
[PHY][I]init eNB: prach_config_index 0
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 0
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 0
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 1
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 1
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 2
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 2
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 3
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 3
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 4
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 4
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 5
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 5
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 6
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 6
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 7
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 7
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 8
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 8
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 9
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 9
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 10
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 10
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 11
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 11
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 12
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 12
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 13
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 13
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 14
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 14
[PHY][I]Allocating Transport Channel Buffers for DLSCH, UE 15
[PHY][I]Allocating Transport Channel Buffer for ULSCH, UE 15
CPU Freq is 1.700122
frame_parms->N_RB_DL=25
frame_parms->N_RB_UL=25
frame_parms->Nid_cell=0
frame_parms->Ncp=0
frame_parms->Ncp_UL=0
frame_parms->nushift=0
frame_parms->frame_type=0
frame_parms->tdd_config=3
frame_parms->tdd_config_S=0
frame_parms->mode1_flag=1
frame_parms->nb_antenna_ports_eNB=1
frame_parms->nb_antennas_tx=1
frame_parms->nb_antennas_rx=1
frame_parms->ofdm_symbol_size=512
frame_parms->nb_prefix_samples=36
frame_parms->nb_prefix_samples0=40
frame_parms->first_carrier_offset=362
frame_parms->samples_per_tti=7680
frame_parms->symbols_per_tti=14
HW: Configuring card 0, nb_antennas_tx/rx 1/1
Card 0, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 0, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 0, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 0, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 1, nb_antennas_tx/rx 1/1
Card 1, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 1, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 1, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 1, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 2, nb_antennas_tx/rx 1/1
Card 2, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 2, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 2, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 2, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 3, nb_antennas_tx/rx 1/1
Card 3, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 3, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 3, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 3, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 4, nb_antennas_tx/rx 1/1
Card 4, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 4, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 4, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 4, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 5, nb_antennas_tx/rx 1/1
Card 5, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 5, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 5, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 5, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 6, nb_antennas_tx/rx 1/1
Card 6, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 6, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 6, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 6, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
HW: Configuring card 7, nb_antennas_tx/rx 1/1
Card 7, channel 0, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 2680000000.000000, rx_freq 2560000000.000000
Card 7, channel 1, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 7, channel 2, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
Card 7, channel 3, Setting tx_gain 60.000000, rx_gain 111.000000, tx_freq 0.000000, rx_freq 0.000000
[HW][I]CPU Affinity of main() function is… CPU_0 CPU_1 CPU_2 CPU_3 CPU_4 CPU_5 CPU_6 CPU_7 CPU_8 CPU_9 CPU_10 CPU_11 CPU_12 CPU_13 CPU_14 CPU_15
[PHY][I]Intializing L2
[MAC][I][l2_init] [MAIN] MAC_INIT_GLOBAL_PARAM IN…
[MAC][I][mac_init_global_param] [MAIN] CALLING RLC_MODULE_INIT…
[MAC][I][mac_init_global_param] [MAIN] RLC_MODULE_INIT OK, malloc16 for mac_rlc_xface…
[MAC][I][mac_init_global_param] [MAIN] malloc16 OK, mac_rlc_xface @ 0x184ea840
[MAC][I][mac_init_global_param] [MAIN] RLC interface setup and init
[PDCP][I]PDCP layer has been initialized
[MAC][I][mac_init_global_param] [MAIN] Init Global Param Done
[MAC][I][l2_init] [MAIN] init eNB MAC functions
[MAC][I][l2_init] [MAIN] init UE MAC functions
[MAC][I][l2_init] [MAIN] PHY Frame configuration
[MAC][I][mac_top_init] [MAIN] Init function start:Nb_UE_INST=0
[MAC][I][mac_top_init] [MAIN] Init function start:Nb_eNB_INST=1
[MAC][I][mac_top_init] [MAIN] calling RRC
[RRC][I][eNB] handover active state is 0
[RRC][I][eNB] eMBMS active state is 0
[MAC][I][mac_top_init] [MAIN][INIT] Init function finished
[SCTP][I][sctp_eNB_task] Starting SCTP layer
[S1AP][I][s1ap_eNB_task] Starting S1AP layer
[UDP][I]Initializing UDP task interface
[UDP][I]Initializing UDP task interface: DONE
[GTPV1U][I]Initializing GTPU stack 0x115af00
ITTI tasks created
Wait for the ITTI initialize message
[ENB_APP][I][eNB_app_register] [eNB 0] eNB_app_register for instance 0
[S1AP][I][s1ap_eNB_handle_register_eNB] Registered new eNB[0] and macro eNB id 42
[S1AP][I][s1ap_eNB_register_mme] [eNB 0] check the mme registration state
[UDP][I]Initializing UDP for local address 192.168.255.6 with port 2152
[UDP][I]Inserting new descriptor for task 11, sd 40
[UDP][I]Initializing UDP for local address 192.168.255.6 with port 2152: DONE
[RRC][I][eNB 0] Received RRC_CONFIGURATION_REQ
[RRC][I][FRAME 00000][eNB][MOD 00][RNTI 0] Init…
[RRC][I][FRAME 00000][eNB][MOD 00][RNTI 0] Checking release
[RRC][I][FRAME 00000][eNB][MOD 00][RNTI 0] Rel14 RRC detected, MBMS flag 0
[SCTP][I][sctp_handle_new_association_req] sctp_bindx SCTP_BINDX_ADD_ADDR socket bound to : 192.168.255.6
[SCTP][I][sctp_handle_new_association_req] Converted ipv4 address 10.42.11.120 to network type
[SCTP][I][sctp_handle_new_association_req] connectx assoc_id 1 in progress…, used 1 addresses
[SCTP][I][sctp_handle_new_association_req] Inserted new descriptor for sd 41 in list, nb elements 1, assoc_id 1
[SCTP][I][sctp_eNB_flush_sockets] Found data for descriptor 41
[SCTP][I][sctp_eNB_read_from_socket] Received notification for sd 41, type 32769
[SCTP][I][sctp_eNB_read_from_socket] Client association changed: 0
[SCTP][I][sctp_get_peeraddresses] ----------------------
[SCTP][I][sctp_get_peeraddresses] Peer addresses:
[SCTP][I][sctp_get_peeraddresses] - [10.42.11.120]
[SCTP][I][sctp_get_sockinfo] ----------------------
[SCTP][I][sctp_get_sockinfo] SCTP Status:
[SCTP][I][sctp_get_sockinfo] assoc id …: 1
[SCTP][I][sctp_get_sockinfo] state …: 4
[SCTP][I][sctp_get_sockinfo] instrms …: 2
[SCTP][I][sctp_get_sockinfo] outstrms …: 2
[SCTP][I][sctp_get_sockinfo] fragmentation : 1452
[SCTP][I][sctp_get_sockinfo] pending data .: 0
[SCTP][I][sctp_get_sockinfo] unack data …: 0
[SCTP][I][sctp_get_sockinfo] rwnd …: 106496
[SCTP][I][sctp_get_sockinfo] peer info :
[SCTP][I][sctp_get_sockinfo] state …: 2
[SCTP][I][sctp_get_sockinfo] cwnd …: 4380
[SCTP][I][sctp_get_sockinfo] srtt …: 0
[SCTP][I][sctp_get_sockinfo] rto …: 3000
[SCTP][I][sctp_get_sockinfo] mtu …: 1500
[SCTP][I][sctp_eNB_read_from_socket] Comm up notified for sd 41, assigned assoc_id 1
[S1AP][I][s1ap_eNB_generate_s1_setup_request] 42 -> 0002a0
[SCTP][I][sctp_send_data] Successfully sent 59 bytes on stream 0 for assoc_id 1
[SCTP][I][sctp_eNB_read_from_socket] Received notification for sd 41, type 32777
[SCTP][I][sctp_eNB_read_from_socket] [1][41] Msg of length 44 received from port 36412, on stream 0, PPID 18
[S1AP][I][s1ap_decode_s1ap_s1setupresponseies] Decoding message S1ap_S1SetupResponseIEs (/root/openairinterface5g/cmake_targets/lte_build_oai/build/CMakeFiles/R10.5/s1ap_decoder.c:3535)
[S1AP][I][s1ap_eNB_handle_s1_setup_response] servedGUMMEIs.list.count 1
[S1AP][I][s1ap_eNB_handle_s1_setup_response] servedPLMNs.list.count 1
[ENB_APP][I][eNB_app_task] [eNB 0] Received S1AP_REGISTER_ENB_CNF: associated MME 1
[RRC][I][eNB 0] Configuration SIB2/3, MBMS = 0
[MAC][I][rrc_mac_config_req] [CONFIG][eNB 0/0] Configuring MAC/PHY
[MAC][I][rrc_mac_config_req] [CONFIG]SIB2/3 Contents (partial)
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.n_SB = 1
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.hoppingMode = 0
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.pusch_HoppingOffset = 0
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.enable64QAM = 0
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.groupHoppingEnabled = 1
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.groupAssignmentPUSCH = 0
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.sequenceHoppingEnabled = 0
[MAC][I][rrc_mac_config_req] [CONFIG]pusch_config_common.cyclicShift = 1
[RRC][I][FRAME 00000][eNB][MOD 00][RNTI 0] OPENAIR RRC IN…
Initializing eNB threads
[PHY][I]Initializing eNB 0 CC_id 0 : (eNodeB_3GPP,synch_to_ext_device)
LMSSDR: Initializing openair0_device for RRH …
cal 0: freq 3500000000.000000, offset 44.000000, diff 940000000.000000
cal 1: freq 2660000000.000000, offset 55.000000, diff 100000000.000000
cal 2: freq 2300000000.000000, offset 54.000000, diff 260000000.000000
cal 3: freq 1880000000.000000, offset 54.000000, diff 680000000.000000
cal 4: freq 816000000.000000, offset 79.000000, diff 1744000000.000000
[RRH] has loaded LMSSDR device.
setup_eNB_buffers: frame_parms = 0x7f109af80788
[PHY][I]Initializing eNB 0 CC_id 0 (eNodeB_3GPP,synch_to_ext_device),
[HW][I][SCHED][eNB] eNB_thread_single started on CPU 15 TID 47, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0 CPU_1 CPU_2 CPU_3 CPU_4 CPU_5 CPU_6 CPU_7 CPU_8 CPU_9 CPU_10 CPU_11 CPU_12 CPU_13 CPU_14 CPU_15
Creating te_thread
[PHY][I]thread te created id=50waiting for sync (eNB_thread_single)
[HW][I][SCHED][eNB] eNB_thread_prach started on CPU 0 TID 51, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0 CPU_1 CPU_2 CPU_3 CPU_4 CPU_5 CPU_6 CPU_7 CPU_8 CPU_9 CPU_10 CPU_11 CPU_12 CPU_13 CPU_14 CPU_15
[HW][I][SCHED][eNB] eNB_thread_synch started on CPU 3 TID 52, sched_policy = SCHED_FIFO , priority = 99, CPU Affinity= CPU_0 CPU_1 CPU_2 CPU_3 CPU_4 CPU_5 CPU_6 CPU_7 CPU_8 CPU_9 CPU_10 CPU_11 CPU_12 CPU_13 CPU_14 CPU_15
waiting for sync (eNB_thread_synch)
Setting eNB buffer to all-RX
Sending sync to all threads
TYPE TO TERMINATE
Entering ITTI signals handler
got sync (eNB_thread_single)
got sync (eNB_thread_synch)
Connecting to device: SoDeRa, media=USB 3.0, module=STREAM, addr=04b4:00f1
[WARNING] Firmware version mismatch!
Expected firmware version 7, but found version 2
Expected gateware version 1, revision 20
[INFO] CLK0 fOut = 27 MHz Multisynth Divider 33 0/1 R divider = 1 source = PLLA
[INFO] CLK1 fOut = 27 MHz Multisynth Divider 33 0/1 R divider = 1 source = PLLA
[INFO] CLK2 fOut = 27 MHz Multisynth Divider 8 0/1 R divider = 1 source = PLLA
[INFO] CLK3 fOut = 27 MHz Multisynth Divider 8 0/1 R divider = 1 source = PLLA
[INFO] CLK4 fOut = 27 MHz Multisynth Divider 8 0/1 R divider = 1 source = PLLA
[INFO] CLK5 fOut = 27 MHz Multisynth Divider 8 0/1 R divider = 1 source = PLLA
[INFO] CLK6 fOut = 27 MHz Multisynth Divider 8 0/1 R divider = 1 source = PLLA
[INFO] CLK7 fOut = 27 MHz Multisynth Divider 8 0/1 R divider = 1 source = PLLA
[INFO] Si5351C: VCOA = 891 MHz Feedback Divider 35 41943/65536
[INFO] Si5351C: VCOB = 891 MHz Feedback Divider 35 41943/65536
MCU algorithm time: 103 ms
Set sample rate 7.680000 MHz
Set TX frequency 2680.000000 MHz
TX ch:0 filter calibration failed, bw:5.000000MHz
Chip mask revision 0 not supported, contact support
RX ch:0 calibration failed, bw:5.000000 MHz
Feature is not available on this chip revision
TX ch:0 calibration failed, bw:5.000000MHz
SR: 7.680 MHz
SR: 7.680 MHz
/root/openairinterface5g/targets/RT/USER/lte-softmodem.c exit_fun() Exiting OAI softmodem: problem receiving samples
[UDP][W]Received TERMINATE_MESSAGE
closing all tasks
ready_tasks 0
waiting for XFORMS thread
stopping MODEM threads
Killing eNB 0 processing threads
Exiting eNB thread PRACH
libusbx: warning [libusb_exit] application left some devices open
Thanks,
Moshiur
