Hi there.
Just received LimeSDR Mini but cannot make it work in Ubuntu 16.04 with Gnuradio nor gqrx showing varied errors, so I decided to uninstall .debs and rebuild from updated source.
Rebuilt last LimeSuite, LMS7002M-driver and SoapySDR. Soapy is 0.7 but It seems LimeSuite generates 0.6 Soapy module.
SoapySDRUtil --info
Search path: /usr/local/lib/SoapySDR/modules0.7
No modules found!
Available factories... No factories found!
if I forced copy fresh compiled libLMS7Support.so to Soapy module dir …
Module found: /usr/local/lib/SoapySDR/modules0.7/libLMS7Support.so
But is 0.6 all inside
$ SoapySDRUtil --find
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules0.7/libLMS7Support.so)
lime failed ABI check: Library ABI=0.7, Module ABI=0.6
No devices found!
So, how do I solve version mismatch?
Regards.
More info
$ LimeUtil --info
Version information:
Library version: v18.03.0-g41ad26b6
Build timestamp: 2018-03-22
Interface version: v2017.12.0
Binary interface: 18.03-1
System resources:
Installation root: /usr/local
User home directory: /home/ismael
App data directory: /home/ismael/.local/share/LimeSuite
Config directory: /home/ismael/.limesuite
Image search paths:
- /home/ismael/.local/share/LimeSuite/images
Supported connections:
* FT601
* FX3
* PCIEXillybus
$ SoapySDRUtil --info
Lib Version: v0.7.0-g824d83e8
API Version: v0.7.0
ABI Version: v0.7
Install root: /usr/local
No modules found!
Available converters...
- CS32 -> [CS32]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- S32 -> [S32]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
