Installed Ubuntu 20.04 LTS. Installed the packages and ran LimeQuickTest. It failed on the last loopback test. Removed the standard packages and build LimeSuite from source. Now LimeQuickTest doens’t find the Lime SDR mini.
Bus 001 Device 005: ID 203a:fffa Parallels Virtual Printer (Canon MG5500 series)
Bus 001 Device 004: ID 203a:fffa Parallels Virtual Printer (Brother MFC-9340CDW)
Bus 001 Device 003: ID 203a:fffa Parallels Virtual Printer (Print to PDF (Mac Desktop))
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 0403:601f Future Technology Devices International, Ltd LimeSDR Mini
Bus 004 Device 002: ID 203a:fff9 Parallels USB Camera
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 203a:fffc Parallels Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
lime@lime-Parallels-Virtual-Platform:~/LimeSuite$ LimeQuickTest
->Start time: Tue Apr 27 15:26:27 2021
Error: No Devices Connected
Failed to connect
Ok fixed the package list and rebuilt. Now it finds the LimeSDR but the loopback test failes:
lime@lime-Parallels-Virtual-Platform:~/LimeSuite/builddir$ LimeQuickTest
->Start time: Tue Apr 27 15:36:40 2021
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D40E13C0638D2, HW=2, GW=1.30
Serial Number: 1D40E13C0638D2
Chip temperature: 59 C
->REF clock test
Test results: 7516; 20712; 33909 - PASSED
Results : 6711081 (min); 6711246 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 06 1B 12 06 1B 03
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-19.8 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-21.4 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.38 seconds
Looks like when the board is cold, the test passes:
->Start time: Tue Apr 27 15:48:08 2021
Chip temperature: 27 C
->REF clock test
Test results: 2152; 15349; 28546 - PASSED
Results : 6711011 (min); 6711179 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-18.6 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-19.9 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 3.25 seconds
