I just removed my LimeSDR Mini V2 from my PortDown Box which had been working
very well, as I was going to mount into a metal case, until this is had been
working extremely well since I received it
When I plugged the lime back into my computer later on I have found that it
does not how any LED’s and also is UNKNOWN
Is there a version of firmware that I can try and reflash this with and how do
I got about this
Any assistance would be greatly appreciated
Regards
Ray VK5RR
Sounds like we know what the answer will be, but as a first step can you run LimeQuickTest and post the results. There should be nothing connected to the RF connectors when you do this and it should be plugged directly into a USB 3.0 port on your computer.
This is a really old version of Lime Suite and dates back to before LimeSDR Mini v2. The Pothos Windows installer needs updating and in the meantime is there a Linux computer you could try this from? You should have the latest version of Lime Suite, v23.11.0, installed.
Where do we find the latest version of the pothos installer, the website downloads.myriadrf.org/builds/PothosSDR/
installs “LimeSuite version: 20.10.0-PothosSDR-2021.07.25-vc16-x64”
The Pothos software is maintained by a third party and as I say, the Windows installer needs updating and if you could please try using a Linux computer, unless you are comfortable compiling Lime Suite for Windows.
