So i downloaded and ran the latest LimeQuickTest executable to test the device and got the following log:
->Start time: Fri Sep 17 16:36:32 2021
->Device: LimeSDR Mini, media=USB 2, module=FT601, serial=1D53AFDB8144F9, index=0, HW=2, GW=1.28
Warning: USB3 not available
Serial Number: 1D53AFDB8144F9
Chip temperature: 36 C
->REF clock test
Test results: 43026; 56201; 3884 - PASSED
Results : 6711030 (min); 6711187 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 07 0F 13 07 0F 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-20.9 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-21.0 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 5.87 seconds
Also, There is nothing connected the SMA connectors. (Do I need to add an antenna here?)
Also I am pretty much new to SDR, my previous background has been in developing FPGA systems, so can anybody also please guide me in how to get started with this device? (My aim is to develop signal processing systems and deploy them on limeSDR)
