I’m new to SDR and to the LimeSDR Mini as-well, I have an IT background so I thought it wouldn’t be to difficult to get going with it. But I’m struggling. I’m searching now for 2 days to find a solution to my problem but I cant find anything reassembling the issue.
The setup and problem
I have the LimesSDR mini (which I updated to the newest firmware) who I use with in windows 10
with the SDR-RADIO.com application. The stick is visible in the software and I can use it as-well. But I only get static and no signals at all, except for one signal in the middle of the screen (no matter what frequency I tune in the one signal stays visible in the middle of the screen)
I use 2 tplink antennas from my router, so I think I should at least be able to tune in to an FM radio station. I hope that someone can point me in the right direction. Perhaps someone here had the same issue and solved it. Thank you.
I got the correct LNA port selected and configured the software as set by the website (www.sdr-radio.com/limesdr). The only difference is that my setup states LNAL_NC and the websites settings stat LNAL. The software notes that its not connected. But I have the 2 antennas screwed on tightly and just checked again to make sure. Hope its not broke, and that its just a setting somewhere. Thanks again.
The LMS7002M chip used in the LimeSDR Mini has 3x LNA inputs, but only 2x are connected, the High (LNAH) and Wideband (LNAW) inputs. Hence why LNAL is marked “NC” for not connected. So if you select this it doesn’t matter what antenna you attach to the RX port, it will not be connected to the chip input. Hence you will not receive anything. Please select LNAH or LNAW.
I did try to the other 2, but with LNAH or LNAW I don’t receive anything, not the faintest signal. Is there something else I can check? Do I need to use bigger/other antennas?
->REF clock test
Test results: 57483; 5143; 18340 - PASSED
Results : 6710990 (min); 6711158 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 16 13 0A 16 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
i see this topic is already from januar but never mind:
i think you have used reverse polarity antennas!!
so…on the female sma plug on the lime sdr there will be no contact at all
