I’m using LimeSDRmini on Linux Mint on USB3 port with gnuradio gr-osmocom-source
and gr-LimeSuite-source blocks
Problem with RxPath:
i can’t receive any signals, no radioBC, no ISM, no GSM …
Tuning to the frequencies seems working
The FFTsink shows a powerful center peak at all tuned frequencies.
In the meantime i think the Mini is broken in the RxPath, any suggestions?
Output of osmocom-source:
gr-osmosdr v0.1.4-98-gc653754d (0.1.5git) gnuradio 3.7.11.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy soapy redpitaya
[INFO] Make connection: ‘LimeSDR Mini [USB 3.0] 1D3AD4B1C886BA’
[INFO] Reference: 4e+07 MHz
[INFO] RX LPF configured
e[1me[31m[ERROR] Rx Calibration: Frequency out of range, available range: from 2.5 to 120 MHze[0m
Output of LimeSuite-Source (RX) block
Devices found: 1
Device list:
Nr.:|0|device:|LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3AD4B1C886BA
New connection
Device number 0 from the list is used.
INFO: device_handler::set_chip_mode(): SISO mode set for device number 0.
RX LPF configured
Soapy installed from source:
Found device 0
addr = 24607:1027
driver = lime
label = LimeSDR Mini [USB 3.0] 1D3AD4B1C886BA
media = USB 3.0
module = FT601
name = LimeSDR Mini
serial = 1D3AD4B1C886BA
LimeSuite installed from source
LimeSuite information summary
Version information:
Library version: v18.04.1-g1c490687
Build timestamp: 2018-04-26
Interface version: v2018.3.0
Binary interface: 18.04-1
System resources:
Installation root: /usr/local
User home directory: /home/peter
App data directory: /home/peter/.local/share/LimeSuite
Config directory: /home/peter/.limesuite
Image search paths:
- /home/peter/.local/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
LimeSuiteGui get info summary
[05:35:04] INFO: Disconnected control port
[05:35:09] INFO: Reference clock 40.00 MHz
[05:35:09] INFO: Connected Control port: LimeSDR-Mini FW:5 HW:0 Protocol:1 GW:1.24 Ref Clk: 40.00 MHz
[05:36:41] INFO: Disconnected control port
