Hi guys,
I am using LimeSuite for development of a custom board. When I try to use LMS_Calibrate function using Lime API I get the following error.**Rx calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
This actually brings down the offset level but it changes some of the parameters like CGEN . Our system is very sensitive to changes in CGEN as the input signal is received from DIQ lines. How do I calibrate without changing CGEN, SXT and SXR ?
I have added my code below for reference —
#include
#include
#include <wiringPi.h>
#include “lime/LimeSuite.h”
#include “lime/LMS7002M.h”
#include “lime/Logger.h”
#include “lime/lms7_device.h”
#include
#define NDEBUG
using namespace std;
using namespace lime;
#define RFD_EXT_CLK 50e6
enum ARGS{
CHAN=1,
enum ERRORS{
NO_DEV=-1,
NOT_OPEN=-2,
ERROR_ARG=-3
lms_device_t* device = NULL;
int my_Init() {
struct regVal
uint16_t adr;
uint16_t val;
const std::vector<regVal> initVals = {
{0x0022, 0x0FFF}, {0x0023, 0x5550}, {0x002B, 0x0038}, {0x002C, 0x0000},
{0x002D, 0x0641}, {0x0086, 0x4101}, {0x0087, 0x5555}, {0x0088, 0x0525},
{0x0089, 0x1078}, {0x008B, 0x218C}, {0x008C, 0x267B}, {0x00A6, 0x000F},
{0x00A9, 0x8000}, {0x00AC, 0x2000}, {0x0108, 0x318C}, {0x0109, 0x57C1},
{0x010A, 0x154C}, {0x010B, 0x0001}, {0x010C, 0x8865}, {0x010E, 0x0000},
{0x010F, 0x3142}, {0x0110, 0x2B14}, {0x0111, 0x0000}, {0x0112, 0x000C},
{0x0113, 0x03C2}, {0x0114, 0x01F0}, {0x0115, 0x000D}, {0x0118, 0x418C},
{0x0119, 0x5292}, {0x011A, 0x3001}, {0x011C, 0x8941}, {0x011D, 0x0000},
{0x011E, 0x0984}, {0x0120, 0xE6B4}, {0x0121, 0x3638}, {0x0122, 0x0514},
{0x0123, 0x200F}, {0x0200, 0x00E1}, {0x0208, 0x017B}, {0x020B, 0x4000},
{0x020C, 0x8000}, {0x0400, 0x8081}, {0x0404, 0x0006}, {0x040B, 0x1020},
{0x040C, 0x00FB}
LMS7_Device* dev=(LMS7_Device*)device;
for(int i=0;i<1;i++){
LMS7002M* lms =((LMS7_Device*)device)->GetLMS() ;
// if (lms->ResetChip() != 0)
// return -1;
LMS_WriteParam(device,LMS7param(MAC), 1);
for (auto i : initVals)
LMS_WriteLMSReg(device,i.adr, i.val);
LMS_WriteParam(device,LMS7param(MAC), 2);
if (i.adr >= 0x100)
lms->EnableChannel(false, false);
lms->EnableChannel(true, false);
if (dev->SetFrequency(true,2*i,2200e6)!=0)
return -1;
if (dev->SetFrequency(false,2*i,2300e6)!=0)
return -1;
if (dev->SetRate(10e6,2)!=0)
return -1;
return 0;
int main(int argc,char** argv){
int n;
lms_info_str_t list[8];
if(argc!=2){
cout<<"USAGE :sudo ./dcoffset_calib <channel-0,1>"<<endl;
return -1;
//INITIALIZE THE BOARD FOR COMMUNCATION
//get device list
if((n = LMS_GetDeviceList(list)) < 0){
cout<<"Could not get devices";
return NO_DEV;
if(LMS_Open(&device,list[0],NULL)){
cout<<"Could not open device";
return NOT_OPEN;
int channel = atoi(argv[CHAN]);
if(channel >1 || channel <0 ){
cout<<"Channel must be 0 or 1"<<endl;
return -1;
LMS_WriteParam(device,LMS7param(MAC),channel+1);
LMS_SetClockFreq(device,LMS_CLOCK_REF,RFD_EXT_CLK);
if(my_Init()){
cout<<" INIT FAILED"<<endl;
return -1;
if (LMS_Calibrate(device, LMS_CH_RX,channel, 8e6, 0) != 0){
cout<<"DC offset calibration failed for channel "<<char('A'+channel)<<endl;
