I’m having a problem with my new LimeSDR boards. I am trying to run the LoRa example from here:
LoRa modem with LimeSDR – MyriadRF
and I get the hollowing output:
[15:34:42.655221] PothosFlow.MainWindow: Welcome to Pothos v0.6.1-PothosSDR-2018.04.26-vc14-x64
[15:34:42.754976] PothosFlow.GraphEditor: Loading C:/Users/ak/Documents/SDR/LoRa-SDR/examples/lora_sdr_relay.pothos
[15:34:43.140839] PothosFlow.MainWindow: Initialization complete
[15:34:44.782000] SoapySDR: Make connection: ‘LimeSDR-USB [USB 3.0] 9070602431B19’
[15:34:44.962000] SoapySDR: Reference clock 30.72 MHz
[15:34:44.963000] SoapySDR: Device name: LimeSDR-USB
[15:34:44.963000] SoapySDR: Reference: 3.072e+07 MHz
[15:34:45.342000] SoapySDR: LMS7002M calibration values caching Disable
[15:34:46.086000] : [INFO] [UHD] Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_3.11.0.1-0-ge00f1f37
[15:34:53.743000] SoapySDR: Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
[15:34:53.916000] SoapySDR: Rx calibration finished
[15:34:54.629000] SoapySDR: popping from TX, samples popped 0/1020
[15:34:55.509000] SoapySDR: popping from TX, samples popped 0/1020
[15:34:56.520000] SoapySDR: popping from TX, samples popped 0/1020
If I connect the board to LimeSuite and try ‘Calibrate All’ I get the same error:
[12:57:04] INFO: Reference clock 30.72 MHz
[12:57:04] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.16 Ref Clk: 30.72 MHz
[12:57:08] ERROR: Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
If, however I update the firmware from LimeSuite (Modules->Programming), reset the module to ‘Default’ configuration, calibration with LimeSuite is successful, but as soon as I try to run the LoRa example, it fails again with the same error, and LimeSuite cannot calibrate until I reprogram the board.
I’m working on Windows 10, x64 if it matters. I tried this on two boards and the results are identical. Any help would be appreciated.
