Hi @IgnasJ,
How can I run the calibration routine 5 and 6(Calibrate RX analog filter and Calibrate TX analog filter) via the Lime Suite API ?
LMS_SetLPFBW() calibrates RX/TX filter.
Hi @IgnasJ,
Now I am able to set the LPF Bandwidth successfully . I am using LMS_Calibrate() to do RX chain calibration and it gives me the following error
Rx calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?) .
I am not using LMS_Init as this is a custom board . I have the following questions —
- Do I have to enable some components before using LMS_Calibrate ?
Hi @IgnasJ , your inputs are required .
Calibration should be performed after RF chain is properly configured (RF frequency, module enables, , antenna path, gains…).
The error indicates that signal level is to low (may be because of disabled modules or low gain settings).
-Ignas
Hi @IgnasJ,
It would be great if you could tell me which modules to enable specifically . I’m setting all gains to maximum and still getting this error .
Regards,
KishoreS
Hi @IgnasJ,
It is not an issue related to gain setting (it still fails with maximum gain ) . So it would be great if you tell me which modules to enable .
Using LimeSuite API functions the following sequence should be enough:
LMS_Init()
LMS_EnableChannel()
LMS_SetLOFrequency()
Basically, LMS chip should be ready to receive/transmit, when running calibration.
