We are using the LMS_Calibrate function from LimeSuite to perform Tx and Rx calibrations on our custom board.
We start of by dong Rx calibration first. Is this ok? (Or should Tx cal be done first?)
After performing Rx calibration, the following are observed:
2.1) Gains are reset or (are significantly different)
2.2) DC offset is corrected
2.3) IQ imbalance is NOT corrected (in fact it is the same as before (based on the image level from a FFT plot)) -
We also started doing Tx calibration but get a message that Tx signal too weak.
Please advise,
Thanks,
