pe2ben
29 December 2018 09:48
1
The LimeQuickTest TX_1 -> LNA_W give me the following results:
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.4 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.6 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-19.8 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-22.7 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.4 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.4 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Is this a serious Problem? I can’t see any damage.
Regards Ben
Hello everyone,
Could this fault caused by the HF mod done by Lime (LN54 - RX2_W)?
Do I have send it back or is this normal (-22.7 dBFS) after that mod?
Regards Ben
I have the exact same issue.
I noticed however that all tests pass when i disconnect the antenna from TX1_1.
Can you reproduce ?
Anyone could confirm that limesdr-usb is supposed to pass all tests from LimeQuickTest ?
Thank you
Regards,
Fred
Hello Fred,
The first time without a antenna all the tests passed.
But after I connect the antenna again the loopback test failed.
After this test I disconnect the antenna and I would expect that all the tests would be passed now but that was not the case.
It doesn’t matter on witch port the antenna is. No change.
So after one time passed without antenna connected the fault situation is the same again.
Strange problem…
Regard Ben
Update:
It looks like the problem start a short time (1 a 2 minutes) after a the limeSDR is connected.
Only just after startup there is no problem.
Maybe temperature related ?
zeewox
22 January 2019 06:36
6
@pe2ben mine fails even on cold boot.
@andrewback hello, could you please advise ? We seem to have a hardware issue since the basic QuickTest fails.
Thank you
Regards
Fred
@zeewox , sure, we will need @zack to make sure that we have tried everything possible and, if it really does look like a hardware problem, arrange RMA.
Zack
23 January 2019 09:24
8
Hi @zeewox ,
Test it using LimeQuickTest and share the result, please.
pe2ben
28 January 2019 21:38
9
Hello Zack,
what can you tell me regarding my output from my LimeQuickTest above?
Regards Ben, PE2BEN
zeewox
1 February 2019 23:49
10
Hello @Zack ,
here’s the result from LimeQuickTest :
->Start time: Sat Feb 2 00:13:13 2019
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=00090726XXXXXXXX
Serial Number: 00090726XXXXXXXX
->FX3 GPIF clock test
Test results: 65211; 3431; 7187 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112947 (min); 5113081 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 19 12 07 19 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.9 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-18.1 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-18.3 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-24.6 dBFS, 5.00 MHz) - FAILED
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.9 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.6 dBFS, 5.00 MHz) - PASSED
Elapsed time: 2.54 seconds
I’ve tested different computers (Windows and Linux), and even tried to downgrade LimeSDR FW, but the problem persists.
Thank you for your help.
Regards.
Hello Zack,
Do I need RMA or is this ok?
Regards Ben
@andrewback or @Zack ,
Please could one of you answer my question.
Regards Ben
Zack
11 March 2019 13:36
13
Hi @pe2ben ,
TX_1 -> LNA_W of CH1 is a little bit lower, but your board is fully operational.
