I have an issue with my LimeSDR USB since I received it. The basic LimeQuickTest program fails the test TX_1 -> LNA_W (CH1) :
->Start time: Sat Feb 2 00:13:13 2019
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=00090726XXXXXXXX
Serial Number: 00090726XXXXXXXX
->FX3 GPIF clock test
Test results: 65211; 3431; 7187 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112947 (min); 5113081 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 19 12 07 19 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.9 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-18.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-18.3 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-24.6 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.9 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.54 seconds
So far I’ve tested many different configurations to try to solve the issue :
- different computers (Windows, Linux, or even VM Ubuntu)
- USB 3 and USB 2 ports
- with and without enclosure
- swap antennas
- firmware downgrading
But the problem persists anyway.
The TX_1 level seems really low, I think there’s a hardware defect.
@andrewback , @Zack , could you please advise ?
Thank you
Regards,
Fred
