I have a LimeSDR Mini, with the QuickTest i have this output:
[ TEST STARTED ]
->Start time: Sun Feb 10 10:41:00 2019
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D40F7476890F5, index=0
Serial Number: 1D40F7476890F5
->REF clock test
Test results: 3787; 16984; 30181 - PASSED
Results : 6711019 (min); 6711174 (max) - PASSED
->Clock Network Test PASSED
data: 18 06 29 18 06 29 2
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
->On board loopback test:
Test 1:(SXR=1000.0MHz, SXT=1005.0MHz, TXPAD=8): Result:(-28.5 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
Test 1:(SXR=2100.0MHz, SXT=2105.0MHz, TXPAD=8): Result:(-16.8 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 4.93 seconds
Is it normal??
