Howdy,
I put the LimeSDR down for quite some time as I couldn’t get the desktop SW configured correctly and then ran out of time, but am back at it. I’m on a Mac and installed LimeSuite with brew which worked brilliantly, but . . .
I can’t update the FW on the LimeSDR using LimeUtil --update. I ran LimeQuickTest and got an OK, but the same FW mismatch that came up with LimeUtil. I’ve tried following the links that come up in the LimeUtil error, but they don’t resolve.
I then tried doing the update in a Windows VM using the Pothos SDR suite, but couldn’t get the drivers to recognize the board - sigh.
Eventually after stumbling on a post here I go to the firmware downloads dir on the MyriadRF site (http://downloads.myriadrf.org/project/limesuite/) but am uncertain which files to download for my board - can someone tell me which images for the FW and FPGA I should download. I’ve included the LimeQuickTest output below.
One note, I’ve never touched the FW on this board, so the config mismatch is factory.
Thanks -
Art
LimeQuicktest
->Start time: Thu Mar 7 15:22:31 2019
Firmware version mismatch!
Expected firmware version 4, but found version 2
Gateware version mismatch!
Expected gateware version 2, revision 18
But found version 2, revision 5
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060B0046361C
Serial Number: 0009060B0046361C
->FX3 GPIF clock test
Test results: 40365; 44121; 47877 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112949 (min); 5113085 (max) - PASSED
->Clock Network Test PASSED
->Read data: 10 0C 1D 10 0C 1D 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.3 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-15.3 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-17.0 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.7 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 1.43 seconds
