Hey everyone,
I cannot access my LimeSDR anymore through GNURadio.
When I run LimeQuickTest, it shows:
->Start time: Wed Apr 5 07:41:38 2023
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=00090726074F243B
Serial Number: 00090726074F243B
->FX3 GPIF clock test
Test results: 25977; 29733; 33489 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112849 (min); 5112991 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 1A 12 07 1A 03
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencyCGEN(80 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.99 seconds
What can I do to solve this problem?
Thanks in advance.
