This situation I have not been able to resolve.
I am sure that the enough external power supply(12V) and USB 3 cable have no damage because the other LimeSDR test is normal.
I try to update everything (FPGA, FX3 firmware, driver, press reset), but it hasn’t improve.
What else could I do to solve this happen?
-Quick Test-
->Start time: Mon Oct 12 15:19:25 2020
Gateware version mismatch!
Expected gateware version 2, revision 23
But found version 65535, revision 65535
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009083401891D22, index=0, HW=127, GW=65535.65535
Serial Number: 0009083401891D22
Chip temperature: 45 C
->FX3 GPIF clock test
Test results: 65535; 65535; 65535 - FAILED
->FX3 GPIF clock test FAILED
->Si5351C test
CLK0: 65535 / 17554 - FAILED
CLK1: 65535 / 17554 - FAILED
CLK2: 65535 / 17554 - FAILED
CLK3: 65535 / 17554 - FAILED
CLK4: 65535 / 17554 - FAILED
CLK5: 65535 / 17554 - FAILED
CLK6: 65535 / 17554 - FAILED
FAILED
->ADF4002 Test
Result: 65535 - FAILED
FAILED
Results : 4294967295 (min); 4294967295 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: 14 09 11 14 0A 08 17
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
TuneVCO(CGEN) - failed to lock (cmphl!=3)
SetFrequencyCGEN(80 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.10 seconds
