Can anyone suggest a solution to this problem? I’m using Limesdr USB to connect to LTE. I get a signal, and my phone detects it, but after a minute it drops. The signal and internet are also dead.
Please provide more information, which LTE stack you are using, and the configuration files.
We use a SIM card programmer and a special version of Linux with pre-installed software.
Please contact the developer for support.
Which of the LTE applications you are running? srsRAN?
The release log says last update of LimeSuiteNG was on 8/2/2025, which is quite old. Also not sure which library the srsRAN is using, whether the legacy LimeSuite, or LimeSuiteNG.
It would be best to build the latest LimeSuiteNG and srsRAN from latest sources:
