I just received a LimeSDR and I’m working on setting it all up, however whenever I run a LimeQuickTest in both Windows and Linux, I get the following:
->Read data: 65 5B 00 EB 0A 0C 00
->FPGA EEPROM Test FAILED
The unit passes all other tests.
Any ideas on what to do to resolve it?
Thanks in advance.
Version information:
[11:47:20] INFO: Reference clock 30.72 MHz
[11:47:20] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.21 Ref Clk: 30.72 MHz
Full quicktest results:
->Start time: Fri Sep 11 11:39:42 2020
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009081C05C1250A, index=0
Serial Number: 0009081C05C1250A
->FX3 GPIF clock test
Test results: 36570; 40326; 44082 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112893 (min); 5113032 (max) - PASSED
->Clock Network Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.0 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-14.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-16.9 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.2 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests FAILED <=
Elapsed time: 2.24 seconds
