Hi guys,
I have recentely gotten a LimeSDR USB V1.4, and am having an issue when doing the USB quick test. I am able to successfully connect the board using LimeSuiteGUI, but when I load the self_test.ini file, I get the following error:
[14:00:54] INFO: Reference clock 30.72 MHz
[14:00:54] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.21 Ref Clk: 30.72 MHz
[14:01:01] WARNING: SetPllFrequency: error configuring phase
[14:01:01] ERROR: LML RX phase search FAIL
[14:01:01] ERROR: LML TX phase search FAIL
I have used the LimeUtil --update, and get the following error:
C:\Program Files\PothosSDR\bin>LimeUtil --update
Connected to [LimeSDR-USB [USB 2.0] 90726074E2721]
Existing firmware is same as update (4)
Existing gateware is same as update (2.21)
Firmware and Gateware update is not required.
Also using the LimeSDR TestAPP, I get the following messages:
I have tried both using USB 3 and 2, and tried on a Raspberry Pi 4 and Windows, but both still unsuccessful. After doing tons of research, I have found that there are others with similar issues and had to request an RMA from Crowd Supply, hopefully this is not the case for me.
I appreciate any help!!
