LimeSDR mini v2.2 in Windows 11: No Samples or timeout
I’m struggling to get my LimeSDR mini v2.2 running under Windows 11 25H2.
Can you provide information what I’m doing wrong?
-> Which driver do I need (WinUSB or FTDI)? LimeSuite only seems to detect the SDR if the FTDI driver 1.3.0.10 is used. Is there a pre-compiled LimeSuite supporting WinUSB?
-> Which gateware version do I need? Is there a compatibility list for LimeSuite Legacy/LimeSuiteNG?
-> Which FT60X Mode do I need (245 or 600)?
Here are more details and some logs:
LimeSDR Mini v2.2
  • FT601 config 100MHz, 600Mode, 2 Channels
  • FT3XX driver FTD3XXDriver_WHQLCertified_1.3.0.10_Installer.exe
  • LimeSDR Mini v2.2, FW 11, GW 3, rev 12
  • Windows 11 25H2 Version 10.0.26200.8037
  • Lenovo E490 USB3.0 Port
  • bitstream limesdr_mini_v2.mcs from GitHub - myriadrf/LimeSDR_GW: LiteX-based gateware for LimeSDR boards. · GitHub flashed with JTAG/diamond programmer 3.14
  • limeSuiteNG … No samples or timeout
  • limeSuite … No samples or timeout
LimeSuiteNG from Releases · myriadrf/LimeSuiteNG · GitHub > Actions > Build 850
limedevice --full
Found 1 device(s) :
0: LimeSDR Mini, media=USB3.0, addr=0403:601f, serial=1D90F5E5F75222
Expansion name : UNSUPPORTED
Firmware version : 11
Gateware version : 3
Gateware revision : 12
Gateware target board : LimeSDR-Mini
Hardware version : 5
Protocol version : 1
Serial number : 8322160124187170
SPI slave devices :
FPGA
LMS7002M
Memory devices :
FPGA/FLASH
GPS Lock:
GPS - 3D
Glonass - 3D
Galileo - 3D
Beidou - 3D
Sensors:
Temperature(LMS7002) : 43.248┬░C
VCTCXO DAC (runtime) : 566
Board Temperature : 53C
limeconfig --initialize --log=debug
FPGA: StopStreaming
lms7002m_set_tx_lpf: bandwidth(20000000): LAD=140, H=0
INT 57, FRAC 385875, DIV_OUTCH_CGEN 18
CGEN_VCO 14720000 Hz, RefClk 40000000 Hz
Calibrating CG_IAMP_TBB:
CG_IAMP_TBB(1) RSSI:0x000011B4 approx. -23.42 dBFS
CG_IAMP_TBB(2) RSSI:0x00001D2D approx. -19.08 dBFS
CG_IAMP_TBB(3) RSSI:0x00002D3B approx. -15.27 dBFS
CG_IAMP_TBB(4) RSSI:0x000039D7 approx. -13.14 dBFS
CG_IAMP_TBB(5) RSSI:0x00004A17 approx. -10.98 dBFS
CG_IAMP_TBB(6) RSSI:0x000055A7 approx. -9.72 dBFS
CG_IAMP_TBB(7) RSSI:0x000065C7 approx. -8.23 dBFS
CG_IAMP_TBB(8) RSSI:0x000071E2 approx. -7.25 dBFS
CG_IAMP_TBB(9) RSSI:0x00008205 approx. -6.10 dBFS
CG_IAMP_TBB(10) RSSI:0x00008DBC approx. -5.35 dBFS
CG_IAMP_TBB(11) RSSI:0x00009DCC approx. -4.42 dBFS
CG_IAMP_TBB(12) RSSI:0x0000AA81 approx. -3.74 dBFS
CG_IAMP_TBB(13) RSSI:0x0000BAB1 approx. -2.96 dBFS
lms7002m_set_rx_lpf: bandwidth(20000000): TIA_C=242, TIA_RCOMP=11, TIA_CCOMP=2, RX_L_C=59, RX_H_C=255
Sampling rate set(20.000 MHz): CGEN:160.000 MHz, Decim: 2^1, Interp: 2^1
INT 63, FRAC 0, DIV_OUTCH_CGEN 7
CGEN_VCO 0 Hz, RefClk 40000000 Hz
FPGA SetPllFrequency: PLL[0] input:40.000 MHz clockCount:4
CLK[3] Fout:40.000 MHz bypass:0 phase:139.06 findPhase: 1
FPGA PLL[0] M=32, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
CLK[1] Fout:40.000 MHz bypass:0 phase:100.45 findPhase: 1
DeviceRegistry Removed: FTDI
DeviceRegistry Removed: FX3
limetrx -s10000
StreamComposite: not enough samples
middle LED blinks red 2 times between standard green blinks
limeflash -l
Available targets:
FPGA/FLASH
limeflash --target=“FPGA/FLASH” bitstreams-ng\limesdr_mini_v2.mcs
File size : 4780235 bytes.
Programming failed! Undefined/Failure
Device programming failed.
LimeSuiteGUI LimeSuiteGUI_22.09.0.exe
  • Help > About: 22.09.0-ge829d3ed
  • Options > Connectionsettings: LimeSDR Mini [USB 3] 1D90F5E5F75222 > Connect
  • CLKGEN > (CLK_H 160MHz, CLKH_OV_CLKL 4) > Calculate > Tune
  • XSR > Frequency 100 MHz > Calculate > Tune
  • Modules > FFTviewer > Start … nothing happens, middle LED blinks red 1 time between standard green blinks
Hello ingo.zettl,
It seems a wrong bitstream for LimeSDR Mini V2 was pushed to github by mistake during the most recent release.
The correct bitstream is now pushed to the master branch.
If programming using a JTAG cable: LimeSDR_GW/bitstream/LimeSDR_Mini_V2/limesdr_mini_v2.mcs at master · myriadrf/LimeSDR_GW · GitHub
If programming using Limesuite: LimeSDR_GW/bitstream/LimeSDR_Mini_V2/limesdr_mini_v2.bit at master · myriadrf/LimeSDR_GW · GitHub
Let me know if flashing this bitstream resolves your issue.
Thanks a lot for your effort. I was able to flash the binary, now I sometimes get some samples but then they seem to be all zero.
C:\Software\limesuiteng\bin>limedevice --full
Found 1 device(s) :
SPI slave devices :
FPGA
LMS7002M
Memory devices :
FPGA/FLASH
GPS Lock:
GPS - 3D
Glonass - 3D
Galileo - 3D
Beidou - 3D
Sensors:
Temperature(LMS7002) : 55.512┬░C
Board Temperaturen : 55.5C
C:\Software\limesuiteng\bin>limeconfig --initialize --log=debug
FPGA: StopStreaming
CG_IAMP_TBB(1) RSSI:0x00001334 approx. -22.71 dBFS
CG_IAMP_TBB(2) RSSI:0x00001E27 approx. -18.79 dBFS
CG_IAMP_TBB(3) RSSI:0x00002D9D approx. -15.20 dBFS
CG_IAMP_TBB(4) RSSI:0x00003A06 approx. -13.11 dBFS
CG_IAMP_TBB(5) RSSI:0x00004A27 approx. -10.98 dBFS
CG_IAMP_TBB(6) RSSI:0x000055B0 approx. -9.72 dBFS
CG_IAMP_TBB(7) RSSI:0x000065CE approx. -8.22 dBFS
CG_IAMP_TBB(8) RSSI:0x000071E3 approx. -7.25 dBFS
CG_IAMP_TBB(9) RSSI:0x00008224 approx. -6.09 dBFS
CG_IAMP_TBB(10) RSSI:0x00008DC2 approx. -5.35 dBFS
CG_IAMP_TBB(11) RSSI:0x00009E06 approx. -4.41 dBFS
CG_IAMP_TBB(12) RSSI:0x0000AA7F approx. -3.75 dBFS
CG_IAMP_TBB(13) RSSI:0x0000BAC8 approx. -2.95 dBFS
C:\Software\limesuiteng\bin>limetrx --fft
Samples received: 8160 Peak amplitude 0.00 dBFS @ 0.000 MHz
LimeSuiteGui_22.09.0.exe:
CLKGEN > (CLK_H 61.44MHz, CLKH_OV_CLKL 4) > Calculate > Tune … has now changed to 61.44MHz
→ middle led flashes red or orange once, sometimes a spectrum is calculated, sometimes only some spurious peaks (?)
and an 8-psk signal point constellation at 1000 samples that is much to clean
→ after one sample, everything stops, no more data, no error, nothing. Is this the intended behavior?
best regards, Ingo
Just another observation: LimeGUI seems to start with a different CLK_H every time it is launched. I now had 61.44MHz, 484.004 MHz, 160 MHz, 371.715MHz. Can you tell me if this is the expected behavior and what clock frequency (range?) the Mini v2.2 requires/supports? Google told me only 30.72MHz would be supported but it basically only halucinated. CLK_H from 16..84MHz with /4 seems to be accepted by the calculate function. LimeGUI detects a LimeSDR-Mini_v2 FW:11 HW:5 Protocol:1 GW3.12 Ref Clk: 40.00MHz
I think your board configuration process might be incomplete.
When using limeGUI, I’d recommend using the starting screen after connection for configuration, as it performs a complete configuration of the board based on the settings entered.
When using CLI tool limeConfig, using just --initialize is insufficient.
To set up the board for receiving RX samples, samplerate, rxen and rxlo parameters should be provided as well, e.g. :
limeConfig --initialize --samplerate=20e6 --rxen=1 --rxlo=2.442e9
More information on CLI tools can be found here:
Let me know if this helps solve your issue.
Thanks again for your efforts. Which version of LimesuiteGui-NG do I need for the Mini v2.2? I completely lost track of all the versions and where to get them, what I have here is 0.3.0-g5bc2d182, Build date 2026-10-11. Still it doesn’t work with the main screen (100MHz RX, 10MHz sample rate, submit). Same Error: No samples or timeout. I never had such issues with any other SDR, are there known issues with the mini v2.2?
I only launched LimeConfig --initialize to show the debug output as I read that it doesn’t do anything as the the APIs are now desctructed correctly and the settings are probably lost.
best regards, Ingo
The version you have should be fine.
Did the GUI print anything in the log at the bottom after submitting the configuration? If there were any errors during configuration, that information should have been printed there. You can also increase the logging verbosity in the bottom right of the window, “Debug” being the highest verbosity.
LimeConfig does work for board configuration. Can you try the example usage I provided in my last message?
In either way, the log messages when performing a full config would be useful for determining the source of your issues.
Hi, just FYI limesuiteng has been updated to allow select which FTDI driver to use:
And there has been some fixes regarding the WinUSB driver:
Thanks a lot for your efforts.
Here is the log output from limeGui.exe (NG), LimeSDR directly connected to the Notebook’s USB 3.0 port. I don’t see any errors before “no samples or timeout”.
LimeSuiteNG LimeGUI 0.3.0-g5bc2d182 2026-10-11
LimeSDR Mini v2.2 directly connected to Lenovo E490 USB3.0 Port, Windows 11 25H2 x64
LimeSuite > debug > open > RxLO 100MHz, TxLO 100MHz, Sample Rate 10MHz > submit
modules > fftviewer > start → middle LED flashes red/orange once, then RX LED flashes shortly > No samples or timeout
[22:22:57] DEBUG: FPGA::DetectRefClk fx3Clk:1e+08
[22:22:57] DEBUG: Estimated reference clock 40.0012 MHz
[22:22:57] INFO: Reference clock 40.00 MHz
[22:22:57] INFO: Connected Device: LimeSDR Mini [USB3.0] 1D90F5E5F75222 FW:11 HW:5 Protocol:1 GW:3.12 Ref Clk: 40.00 MHz
[22:23:45] DEBUG: FPGA: StopStreaming
[22:23:45] DEBUG: lms7002m_set_tx_lpf: bandwidth(20000000): LAD=140, H=0
[22:23:45] DEBUG: INT 57, FRAC 385875, DIV_OUTCH_CGEN 18
[22:23:45] DEBUG: CGEN_VCO 14720000 Hz, RefClk 40000000 Hz
[22:23:45] DEBUG: Calibrating CG_IAMP_TBB:
[22:23:45] DEBUG: CG_IAMP_TBB(1) RSSI:0x0000121B approx. -23.22 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001D8B approx. -18.97 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002D88 approx. -15.21 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(4) RSSI:0x00003A27 approx. -13.09 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(5) RSSI:0x00004A84 approx. -10.93 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(6) RSSI:0x00005635 approx. -9.67 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(7) RSSI:0x00006669 approx. -8.17 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(8) RSSI:0x0000727D approx. -7.20 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(9) RSSI:0x0000831C approx. -6.03 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(10) RSSI:0x00008E92 approx. -5.30 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(11) RSSI:0x00009F17 approx. -4.35 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(12) RSSI:0x0000ABB8 approx. -3.68 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000BBC6 approx. -2.91 dBFS
[22:23:45] DEBUG: lms7002m_set_rx_lpf: bandwidth(20000000): TIA_C=242, TIA_RCOMP=11, TIA_CCOMP=2, RX_L_C=59, RX_H_C=255
[22:23:45] DEBUG: Sampling rate set(20.000 MHz): CGEN:160.000 MHz, Decim: 2^1, Interp: 2^1
[22:23:45] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 7
[22:23:45] DEBUG: CGEN_VCO 0 Hz, RefClk 40000000 Hz
[22:23:45] DEBUG: FPGA SetPllFrequency: PLL[0] input:40.000 MHz clockCount:4
[22:23:45] DEBUG: CLK[3] Fout:40.000 MHz bypass:0 phase:139.06 findPhase: 1
[22:23:45] DEBUG: FPGA PLL[0] M=32, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[22:23:45] DEBUG: CLK[1] Fout:40.000 MHz bypass:0 phase:100.45 findPhase: 1
[22:23:45] DEBUG: CG_IAMP_TBB(1) RSSI:0x000011D9 approx. -23.35 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001D6C approx. -19.01 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002D99 approx. -15.20 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(4) RSSI:0x00003A49 approx. -13.07 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(5) RSSI:0x00004A9E approx. -10.92 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(6) RSSI:0x00005667 approx. -9.65 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(7) RSSI:0x000066B9 approx. -8.15 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(8) RSSI:0x000072ED approx. -7.17 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(9) RSSI:0x0000831D approx. -6.03 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(10) RSSI:0x00008F20 approx. -5.27 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(11) RSSI:0x00009F45 approx. -4.34 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(12) RSSI:0x0000ABE9 approx. -3.67 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000BC5F approx. -2.88 dBFS
[22:23:45] DEBUG: Set Rx LO frequency (100000000 Hz)
[22:23:45] DEBUG: SX VCO:2105032704 Hz, RefClk:40000000 Hz, INT:76, FRAC:0, DIV_LOCH:5, EN_DIV2_DIVPROG:1
[22:23:45] DEBUG: Tuning Rx VCOH (ICT_VCO:220):
[22:23:45] DEBUG: TuneVCO(SXR) - searching interval [0:128]
[22:23:45] DEBUG: binary search:
[22:23:45] DEBUG: csw=64 cmphl=3
[22:23:45] DEBUG: csw=32 cmphl=3
[22:23:45] DEBUG: csw=16 cmphl=3
[22:23:45] DEBUG: csw=8 cmphl=3
[22:23:45] DEBUG: csw=4 cmphl=3
[22:23:45] DEBUG: csw=2 cmphl=2
[22:23:45] DEBUG: csw=3 cmphl=2
[22:23:45] DEBUG: adjust with linear search:
[22:23:45] DEBUG: csw=1 cmphl=2
[22:23:45] DEBUG: csw=0 cmphl=2
[22:23:45] DEBUG: CSW: lowest=0, highest=3, will use=1
[22:23:45] DEBUG: TuneVCO(SXR) - searching interval [128:256]
[22:23:45] DEBUG: csw=192 cmphl=3
[22:23:45] DEBUG: csw=160 cmphl=3
[22:23:45] DEBUG: csw=144 cmphl=3
[22:23:45] DEBUG: csw=136 cmphl=3
[22:23:45] DEBUG: csw=132 cmphl=3
[22:23:45] DEBUG: csw=130 cmphl=3
[22:23:45] DEBUG: csw=129 cmphl=3
[22:23:45] DEBUG: CSW interval failed to lock
[22:23:45] DEBUG: choosing wider CSW locking range: low=0, high=3
[22:23:45] DEBUG: TuneVCO(SXR) - confirmed lock with final csw=1, cmphl=2
[22:23:45] DEBUG: VCOH : csw=1 tune ok
[22:23:45] DEBUG: Selected: VCOH, CSW_VCO: 1
[22:23:45] DEBUG: Set Tx LO frequency (100000000 Hz)
[22:23:45] DEBUG: Tuning Tx VCOH (ICT_VCO:220):
[22:23:45] DEBUG: TuneVCO(SXT) - searching interval [0:128]
[22:23:45] DEBUG: csw=4 cmphl=2
[22:23:45] DEBUG: csw=6 cmphl=3
[22:23:45] DEBUG: csw=5 cmphl=3
[22:23:45] DEBUG: CSW: lowest=0, highest=4, will use=2
[22:23:45] DEBUG: TuneVCO(SXT) - searching interval [128:256]
[22:23:45] DEBUG: choosing wider CSW locking range: low=0, high=4
[22:23:45] DEBUG: TuneVCO(SXT) - confirmed lock with final csw=2, cmphl=2
[22:23:45] DEBUG: VCOH : csw=2 tune ok
[22:23:45] DEBUG: Selected: VCOH, CSW_VCO: 2
[22:23:45] DEBUG: lms7002m_set_rx_lpf: RxLPF bypassed
[22:23:45] DEBUG: lms7002m_set_tx_lpf: TxLPF bypassed.
[22:23:45] DEBUG: CG_IAMP_TBB(1) RSSI:0x00000F58 approx. -24.66 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001A29 approx. -20.03 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(3) RSSI:0x0000293B approx. -16.08 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(4) RSSI:0x000034D5 approx. -13.92 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(5) RSSI:0x000043CF approx. -11.75 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(6) RSSI:0x00004E4C approx. -10.50 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(7) RSSI:0x00005D69 approx. -8.97 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(8) RSSI:0x00006835 approx. -8.02 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(9) RSSI:0x00007706 approx. -6.87 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(10) RSSI:0x0000819F approx. -6.13 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(11) RSSI:0x000090C0 approx. -5.17 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(12) RSSI:0x00009C64 approx. -4.50 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000AB3F approx. -3.71 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(14) RSSI:0x0000B59B approx. -3.20 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(1) RSSI:0x000014A2 approx. -22.09 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(2) RSSI:0x00002307 approx. -17.49 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(3) RSSI:0x0000374D approx. -13.52 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(4) RSSI:0x000046C8 approx. -11.38 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(5) RSSI:0x00005ADA approx. -9.21 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(6) RSSI:0x00006925 approx. -7.94 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(7) RSSI:0x00007D28 approx. -6.43 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(8) RSSI:0x00008B1B approx. -5.51 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(9) RSSI:0x00009EE4 approx. -4.36 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(10) RSSI:0x0000AD3F approx. -3.61 dBFS
[22:23:45] DEBUG: CG_IAMP_TBB(11) RSSI:0x0000C144 approx. -2.66 dBFS
[22:23:45] DEBUG: Sampling rate set(10.000 MHz): CGEN:80.000 MHz, Decim: 2^1, Interp: 2^1
[22:23:45] DEBUG: INT 59, FRAC 0, DIV_OUTCH_CGEN 14
[22:23:45] DEBUG: FPGA SetPllFrequency: PLL[0] input:10.000 MHz clockCount:4
[22:23:45] DEBUG: CLK[3] Fout:10.000 MHz bypass:0 phase:101.86 findPhase: 1
[22:23:45] DEBUG: FPGA PLL[0] M=128, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[22:23:45] DEBUG: CLK[1] Fout:10.000 MHz bypass:0 phase:92.32 findPhase: 1
[22:24:24] DEBUG: show module 209
[22:24:28] DEBUG: FPGA: StopStreaming
[22:24:28] DEBUG: FPGA: StopWaveformPlayback
[22:24:28] DEBUG: FPGA: ResetPacketCounters
[22:24:28] DEBUG: FPGA: ResetTimestamp
[22:24:28] VERBOSE: USB ep:83 Rx0 Setup: usePoll:1 rxSamplesInPkt:1360 rxPacketsInBatch:1, DMA_ReadSize:4096, link:I12, batchSizeInTime:136us FS:10000000.000000, FIFO=1838*1360
[22:24:28] DEBUG: RxSetup wait for Rx worker thread.
[22:24:28] DEBUG: Rx worker thread ready.
[22:24:28] DEBUG: FPGA: StartStreaming
[22:24:28] DEBUG: Rx receive loop start.
[22:24:29] ERROR: No samples or timeout
[22:24:29] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:24:30] ERROR: No samples or timeout
[22:24:30] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:24:31] ERROR: No samples or timeout
[22:24:31] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:24:32] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:24:32] ERROR: No samples or timeout
[22:24:35] ERROR: No samples or timeout
[22:24:35] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:24:35] DEBUG: TRXLooper::Stop()
[22:24:35] DEBUG: TRXLooper: wait for Rx loop end.
[22:24:35] DEBUG: Rx receive loop end.
[22:24:35] VERBOSE: Rx0 stop: packetsIn: 0
[22:24:35] DEBUG: FPGA: StopStreaming
[22:24:35] DEBUG: FPGA: ResetPacketCounters
[22:24:35] DEBUG: FPGA: ResetTimestamp
[22:24:35] DEBUG: RxTeardown wait for Rx worker shutdown.
[22:24:35] DEBUG: Rx worker thread shutdown.
[22:24:39] DEBUG: Close module 209
Here is the log of a second run. The same except some
changed to
[22:57:41] DEBUG: csw=64 cmphl=3
[22:57:41] DEBUG: csw=32 cmphl=3
[22:57:41] DEBUG: csw=16 cmphl=3
[22:57:41] DEBUG: csw=8 cmphl=3
[22:57:41] DEBUG: csw=4 cmphl=2
[22:57:41] DEBUG: csw=6 cmphl=3
[22:57:41] DEBUG: csw=5 cmphl=3
[22:57:41] DEBUG: adjust with linear search:
[22:57:41] DEBUG: csw=3 cmphl=2
[22:57:41] DEBUG: csw=2 cmphl=2
[22:57:41] DEBUG: csw=1 cmphl=2
[22:57:41] DEBUG: csw=0 cmphl=2
[22:57:41] DEBUG: CSW: lowest=0, highest=4, will use=2
There is no antenna connected, so I don’t think I’m anywhere near to -2dBFS.
[22:57:32] DEBUG: FPGA::DetectRefClk fx3Clk:1e+08
[22:57:32] DEBUG: Estimated reference clock 40.0013 MHz
[22:57:32] INFO: Reference clock 40.00 MHz
[22:57:32] INFO: Connected Device: LimeSDR Mini [USB3.0] 1D90F5E5F75222 FW:11 HW:5 Protocol:1 GW:3.12 Ref Clk: 40.00 MHz
[22:57:41] DEBUG: FPGA: StopStreaming
[22:57:41] DEBUG: lms7002m_set_tx_lpf: bandwidth(20000000): LAD=140, H=0
[22:57:41] DEBUG: INT 57, FRAC 385875, DIV_OUTCH_CGEN 18
[22:57:41] DEBUG: CGEN_VCO 14720000 Hz, RefClk 40000000 Hz
[22:57:41] DEBUG: Calibrating CG_IAMP_TBB:
[22:57:41] DEBUG: CG_IAMP_TBB(1) RSSI:0x00010B8C approx. +0.17 dBFS
[22:57:41] DEBUG: lms7002m_set_rx_lpf: bandwidth(20000000): TIA_C=242, TIA_RCOMP=11, TIA_CCOMP=2, RX_L_C=59, RX_H_C=255
[22:57:41] DEBUG: Sampling rate set(20.000 MHz): CGEN:160.000 MHz, Decim: 2^1, Interp: 2^1
[22:57:41] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 7
[22:57:41] DEBUG: CGEN_VCO 0 Hz, RefClk 40000000 Hz
[22:57:41] DEBUG: FPGA SetPllFrequency: PLL[0] input:40.000 MHz clockCount:4
[22:57:41] DEBUG: CLK[3] Fout:40.000 MHz bypass:0 phase:139.06 findPhase: 1
[22:57:41] DEBUG: FPGA PLL[0] M=32, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[22:57:41] DEBUG: CLK[1] Fout:40.000 MHz bypass:0 phase:100.45 findPhase: 1
[22:57:41] DEBUG: CG_IAMP_TBB(1) RSSI:0x000016E8 approx. -21.18 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(2) RSSI:0x00002003 approx. -18.27 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002F13 approx. -14.92 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(4) RSSI:0x00003B96 approx. -12.88 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(5) RSSI:0x00004B6C approx. -10.83 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(6) RSSI:0x0000570B approx. -9.58 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(7) RSSI:0x0000670D approx. -8.12 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(8) RSSI:0x000072F9 approx. -7.17 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(9) RSSI:0x0000832D approx. -6.02 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(10) RSSI:0x00008EC5 approx. -5.29 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(11) RSSI:0x00009EF4 approx. -4.35 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(12) RSSI:0x0000ABDE approx. -3.68 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000BBAC approx. -2.91 dBFS
[22:57:41] DEBUG: Set Rx LO frequency (100000000 Hz)
[22:57:41] DEBUG: SX VCO:2105032704 Hz, RefClk:40000000 Hz, INT:76, FRAC:0, DIV_LOCH:5, EN_DIV2_DIVPROG:1
[22:57:41] DEBUG: Tuning Rx VCOH (ICT_VCO:220):
[22:57:41] DEBUG: TuneVCO(SXR) - searching interval [0:128]
[22:57:41] DEBUG: binary search:
[22:57:41] DEBUG: TuneVCO(SXR) - searching interval [128:256]
[22:57:41] DEBUG: csw=192 cmphl=3
[22:57:41] DEBUG: csw=160 cmphl=3
[22:57:41] DEBUG: csw=144 cmphl=3
[22:57:41] DEBUG: csw=136 cmphl=3
[22:57:41] DEBUG: csw=132 cmphl=3
[22:57:41] DEBUG: csw=130 cmphl=3
[22:57:41] DEBUG: csw=129 cmphl=3
[22:57:41] DEBUG: CSW interval failed to lock
[22:57:41] DEBUG: choosing wider CSW locking range: low=0, high=4
[22:57:41] DEBUG: TuneVCO(SXR) - confirmed lock with final csw=2, cmphl=2
[22:57:41] DEBUG: VCOH : csw=2 tune ok
[22:57:41] DEBUG: Selected: VCOH, CSW_VCO: 2
[22:57:41] DEBUG: Set Tx LO frequency (100000000 Hz)
[22:57:41] DEBUG: Tuning Tx VCOH (ICT_VCO:220):
[22:57:41] DEBUG: TuneVCO(SXT) - searching interval [0:128]
[22:57:41] DEBUG: TuneVCO(SXT) - searching interval [128:256]
[22:57:41] DEBUG: TuneVCO(SXT) - confirmed lock with final csw=2, cmphl=2
[22:57:41] DEBUG: lms7002m_set_rx_lpf: RxLPF bypassed
[22:57:41] DEBUG: lms7002m_set_tx_lpf: TxLPF bypassed.
[22:57:41] DEBUG: CG_IAMP_TBB(1) RSSI:0x00000F5C approx. -24.65 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001A23 approx. -20.03 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002930 approx. -16.08 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(4) RSSI:0x000034C5 approx. -13.93 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(5) RSSI:0x000043DE approx. -11.75 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(6) RSSI:0x00004E7B approx. -10.48 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(7) RSSI:0x00005D6B approx. -8.97 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(8) RSSI:0x0000684D approx. -8.01 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(9) RSSI:0x00007707 approx. -6.87 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(10) RSSI:0x000081B4 approx. -6.12 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(11) RSSI:0x000090C7 approx. -5.17 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(12) RSSI:0x00009C4E approx. -4.50 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000AB18 approx. -3.71 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(14) RSSI:0x0000B575 approx. -3.20 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(1) RSSI:0x00001483 approx. -22.14 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(2) RSSI:0x000022C6 approx. -17.55 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(3) RSSI:0x000036D7 approx. -13.60 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(4) RSSI:0x00004632 approx. -11.45 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(5) RSSI:0x00005A20 approx. -9.28 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(6) RSSI:0x0000684B approx. -8.01 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(7) RSSI:0x00007C2B approx. -6.50 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(8) RSSI:0x000089D5 approx. -5.59 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(9) RSSI:0x00009DDF approx. -4.41 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(10) RSSI:0x0000ABE3 approx. -3.67 dBFS
[22:57:41] DEBUG: CG_IAMP_TBB(11) RSSI:0x0000BFBE approx. -2.73 dBFS
[22:57:41] DEBUG: Sampling rate set(10.000 MHz): CGEN:80.000 MHz, Decim: 2^1, Interp: 2^1
[22:57:41] DEBUG: INT 59, FRAC 0, DIV_OUTCH_CGEN 14
[22:57:41] DEBUG: FPGA SetPllFrequency: PLL[0] input:10.000 MHz clockCount:4
[22:57:41] DEBUG: CLK[3] Fout:10.000 MHz bypass:0 phase:101.86 findPhase: 1
[22:57:41] DEBUG: FPGA PLL[0] M=128, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[22:57:41] DEBUG: CLK[1] Fout:10.000 MHz bypass:0 phase:92.32 findPhase: 1
[22:57:48] DEBUG: show module 209
[22:57:52] DEBUG: FPGA: StopStreaming
[22:57:52] DEBUG: FPGA: StopWaveformPlayback
[22:57:52] DEBUG: FPGA: ResetPacketCounters
[22:57:52] DEBUG: FPGA: ResetTimestamp
[22:57:52] VERBOSE: USB ep:83 Rx0 Setup: usePoll:1 rxSamplesInPkt:1360 rxPacketsInBatch:1, DMA_ReadSize:4096, link:I12, batchSizeInTime:136us FS:10000000.000000, FIFO=1838*1360
[22:57:52] DEBUG: RxSetup wait for Rx worker thread.
[22:57:52] DEBUG: Rx worker thread ready.
[22:57:52] DEBUG: FPGA: StartStreaming
[22:57:52] DEBUG: Rx receive loop start.
[22:57:53] ERROR: No samples or timeout
[22:57:53] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:57:54] DEBUG: USB ep:83 Rx0: 0.000 MB/s | TS:0 pkt:0 o:0(+0) l:0(+0) dma:0/0(+0) swFIFO:0
[22:57:54] ERROR: No samples or timeout
[22:57:56] ERROR: No samples or timeout
[22:57:56] DEBUG: TRXLooper::Stop()
[22:57:56] DEBUG: TRXLooper: wait for Rx loop end.
[22:57:56] DEBUG: Rx receive loop end.
[22:57:56] VERBOSE: Rx0 stop: packetsIn: 0
[22:57:56] DEBUG: FPGA: StopStreaming
[22:57:56] DEBUG: FPGA: ResetPacketCounters
[22:57:56] DEBUG: FPGA: ResetTimestamp
[22:57:56] DEBUG: RxTeardown wait for Rx worker shutdown.
[22:57:56] DEBUG: Rx worker thread shutdown.
[22:58:01] DEBUG: Close module 209
I saw that there might be problems with USB power, so I added an externally powerd USB 3.0 Hub. Now the RX LED stays on and I get lots of Lots of DEBUG: Loss: pkt11174 exp: … got: … diff: +2208, timeDiff: +220800ns errors (expected more than 1000 per second). Messages keep running, RX LED is solid green until Stop button in FFT viewer is pushed. Then Lime Suite NG GUI completely crashes, so unfortunately I can’t get the full log or is there an option to directly log to a file?
LimeSDR Mini v2.2 connected EXSys EX-1234 HMVS externally powerd USB hub and to Lenovo E490 USB3.0 Port, Windows 11 25H2 x64
modules > fftviewer > start → middle LED flashes red/orange once (this time RX LED stays green)
→ lots of DEBUG: Loss messages
→ fft > stop → LimeSuiteGUI Crashes, log cannot be extracted, RX LED stays green
→ kill LimeGUI → RX LED turns off
[22:38:10] DEBUG: FPGA::DetectRefClk fx3Clk:1e+08
[22:38:10] DEBUG: Estimated reference clock 40.0013 MHz
[22:38:10] INFO: Reference clock 40.00 MHz
[22:38:10] INFO: Connected Device: LimeSDR Mini [USB3.0] 1D90F5E5F75222 FW:11 HW:5 Protocol:1 GW:3.12 Ref Clk: 40.00 MHz
[22:38:24] DEBUG: FPGA: StopStreaming
[22:38:24] DEBUG: lms7002m_set_tx_lpf: bandwidth(20000000): LAD=140, H=0
[22:38:24] DEBUG: INT 57, FRAC 385875, DIV_OUTCH_CGEN 18
[22:38:24] DEBUG: CGEN_VCO 14720000 Hz, RefClk 40000000 Hz
[22:38:24] DEBUG: Calibrating CG_IAMP_TBB:
[22:38:24] DEBUG: CG_IAMP_TBB(1) RSSI:0x00001711 approx. -21.12 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001FF0 approx. -18.29 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002E40 approx. -15.08 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(4) RSSI:0x00003A0D approx. -13.10 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(5) RSSI:0x00004A6E approx. -10.94 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(6) RSSI:0x0000560F approx. -9.68 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(7) RSSI:0x0000662D approx. -8.19 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(8) RSSI:0x0000724B approx. -7.22 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(9) RSSI:0x000082B2 approx. -6.05 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(10) RSSI:0x00008E6A approx. -5.31 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(11) RSSI:0x00009ED2 approx. -4.36 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(12) RSSI:0x0000AB6C approx. -3.70 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000BBBD approx. -2.91 dBFS
[22:38:24] DEBUG: lms7002m_set_rx_lpf: bandwidth(20000000): TIA_C=242, TIA_RCOMP=11, TIA_CCOMP=2, RX_L_C=59, RX_H_C=255
[22:38:24] DEBUG: Sampling rate set(20.000 MHz): CGEN:160.000 MHz, Decim: 2^1, Interp: 2^1
[22:38:24] DEBUG: INT 63, FRAC 0, DIV_OUTCH_CGEN 7
[22:38:24] DEBUG: CGEN_VCO 0 Hz, RefClk 40000000 Hz
[22:38:24] DEBUG: FPGA SetPllFrequency: PLL[0] input:40.000 MHz clockCount:4
[22:38:24] DEBUG: CLK[3] Fout:40.000 MHz bypass:0 phase:139.06 findPhase: 1
[22:38:24] DEBUG: FPGA PLL[0] M=32, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[22:38:24] DEBUG: CLK[1] Fout:40.000 MHz bypass:0 phase:100.45 findPhase: 1
[22:38:24] DEBUG: CG_IAMP_TBB(1) RSSI:0x0000154D approx. -21.81 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001F39 approx. -18.49 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002E8C approx. -15.02 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(4) RSSI:0x00003AB8 approx. -13.00 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(5) RSSI:0x00004A5F approx. -10.95 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(6) RSSI:0x0000560E approx. -9.68 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(7) RSSI:0x0000668C approx. -8.16 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(8) RSSI:0x00007266 approx. -7.21 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(9) RSSI:0x000082DA approx. -6.04 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(10) RSSI:0x00008E9A approx. -5.30 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(11) RSSI:0x00009EF9 approx. -4.35 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(12) RSSI:0x0000ABA6 approx. -3.69 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000BBE8 approx. -2.90 dBFS
[22:38:24] DEBUG: Set Rx LO frequency (100000000 Hz)
[22:38:24] DEBUG: SX VCO:2105032704 Hz, RefClk:40000000 Hz, INT:76, FRAC:0, DIV_LOCH:5, EN_DIV2_DIVPROG:1
[22:38:24] DEBUG: Tuning Rx VCOH (ICT_VCO:220):
[22:38:24] DEBUG: TuneVCO(SXR) - searching interval [0:128]
[22:38:24] DEBUG: binary search:
[22:38:24] DEBUG: csw=64 cmphl=3
[22:38:24] DEBUG: csw=32 cmphl=3
[22:38:24] DEBUG: csw=16 cmphl=3
[22:38:24] DEBUG: csw=8 cmphl=3
[22:38:24] DEBUG: csw=4 cmphl=2
[22:38:24] DEBUG: csw=6 cmphl=3
[22:38:24] DEBUG: csw=5 cmphl=3
[22:38:24] DEBUG: adjust with linear search:
[22:38:24] DEBUG: csw=3 cmphl=2
[22:38:24] DEBUG: csw=2 cmphl=2
[22:38:24] DEBUG: csw=1 cmphl=2
[22:38:24] DEBUG: csw=0 cmphl=2
[22:38:24] DEBUG: CSW: lowest=0, highest=4, will use=2
[22:38:24] DEBUG: TuneVCO(SXR) - searching interval [128:256]
[22:38:24] DEBUG: csw=192 cmphl=3
[22:38:24] DEBUG: csw=160 cmphl=3
[22:38:24] DEBUG: csw=144 cmphl=3
[22:38:24] DEBUG: csw=136 cmphl=3
[22:38:24] DEBUG: csw=132 cmphl=3
[22:38:24] DEBUG: csw=130 cmphl=3
[22:38:24] DEBUG: csw=129 cmphl=3
[22:38:24] DEBUG: CSW interval failed to lock
[22:38:24] DEBUG: choosing wider CSW locking range: low=0, high=4
[22:38:24] DEBUG: TuneVCO(SXR) - confirmed lock with final csw=2, cmphl=2
[22:38:24] DEBUG: VCOH : csw=2 tune ok
[22:38:24] DEBUG: Selected: VCOH, CSW_VCO: 2
[22:38:24] DEBUG: Set Tx LO frequency (100000000 Hz)
[22:38:24] DEBUG: Tuning Tx VCOH (ICT_VCO:220):
[22:38:24] DEBUG: TuneVCO(SXT) - searching interval [0:128]
[22:38:24] DEBUG: TuneVCO(SXT) - searching interval [128:256]
[22:38:24] DEBUG: TuneVCO(SXT) - confirmed lock with final csw=2, cmphl=2
[22:38:24] DEBUG: lms7002m_set_rx_lpf: RxLPF bypassed
[22:38:24] DEBUG: lms7002m_set_tx_lpf: TxLPF bypassed.
[22:38:24] DEBUG: CG_IAMP_TBB(1) RSSI:0x00001733 approx. -21.07 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(2) RSSI:0x00001E21 approx. -18.80 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(3) RSSI:0x00002939 approx. -16.08 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(4) RSSI:0x000034CA approx. -13.93 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(5) RSSI:0x000043BB approx. -11.76 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(6) RSSI:0x00004E5D approx. -10.50 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(7) RSSI:0x00005D4C approx. -8.98 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(8) RSSI:0x0000682E approx. -8.02 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(9) RSSI:0x0000771B approx. -6.86 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(10) RSSI:0x00008189 approx. -6.13 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(11) RSSI:0x000090A5 approx. -5.17 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(12) RSSI:0x00009C19 approx. -4.51 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(13) RSSI:0x0000AAD4 approx. -3.73 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(14) RSSI:0x0000B573 approx. -3.20 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(1) RSSI:0x000014B4 approx. -22.06 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(2) RSSI:0x000022ED approx. -17.52 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(3) RSSI:0x000036FC approx. -13.57 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(4) RSSI:0x00004635 approx. -11.45 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(5) RSSI:0x00005A2F approx. -9.28 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(6) RSSI:0x0000684B approx. -8.01 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(7) RSSI:0x00007C30 approx. -6.50 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(8) RSSI:0x00008A2C approx. -5.57 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(9) RSSI:0x00009DF9 approx. -4.41 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(10) RSSI:0x0000AC10 approx. -3.67 dBFS
[22:38:24] DEBUG: CG_IAMP_TBB(11) RSSI:0x0000BFBD approx. -2.73 dBFS
[22:38:24] DEBUG: Sampling rate set(10.000 MHz): CGEN:80.000 MHz, Decim: 2^1, Interp: 2^1
[22:38:24] DEBUG: INT 59, FRAC 0, DIV_OUTCH_CGEN 14
[22:38:24] DEBUG: FPGA SetPllFrequency: PLL[0] input:10.000 MHz clockCount:4
[22:38:24] DEBUG: CLK[3] Fout:10.000 MHz bypass:0 phase:101.86 findPhase: 1
[22:38:24] DEBUG: FPGA PLL[0] M=128, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[22:38:24] DEBUG: CLK[1] Fout:10.000 MHz bypass:0 phase:92.32 findPhase: 1
Here is the requested output of limeconfig:
C:\Software\limesuiteng\bin>limeconfig --initialize --samplerate=20e6 --rxen=1 --rxlo=100e6 --log=debug
FPGA: StopStreaming
CG_IAMP_TBB(1) RSSI:0x00001379 approx. -22.59 dBFS
CG_IAMP_TBB(3) RSSI:0x00002DD8 approx. -15.15 dBFS
CG_IAMP_TBB(4) RSSI:0x00003A3A approx. -13.08 dBFS
CG_IAMP_TBB(5) RSSI:0x00004A55 approx. -10.96 dBFS
CG_IAMP_TBB(6) RSSI:0x00005616 approx. -9.68 dBFS
CG_IAMP_TBB(7) RSSI:0x00006657 approx. -8.18 dBFS
CG_IAMP_TBB(9) RSSI:0x000082F2 approx. -6.04 dBFS
CG_IAMP_TBB(10) RSSI:0x00008EA8 approx. -5.29 dBFS
CG_IAMP_TBB(11) RSSI:0x00009E77 approx. -4.38 dBFS
CG_IAMP_TBB(12) RSSI:0x0000AB5E approx. -3.70 dBFS
CG_IAMP_TBB(13) RSSI:0x0000BB4E approx. -2.93 dBFS
FPGA: StopStreaming
CG_IAMP_TBB(1) RSSI:0x000010F3 approx. -23.80 dBFS
CG_IAMP_TBB(2) RSSI:0x00001CAF approx. -19.23 dBFS
CG_IAMP_TBB(3) RSSI:0x00002D30 approx. -15.28 dBFS
CG_IAMP_TBB(4) RSSI:0x00003A07 approx. -13.11 dBFS
CG_IAMP_TBB(5) RSSI:0x00004A61 approx. -10.95 dBFS
CG_IAMP_TBB(6) RSSI:0x000055FA approx. -9.69 dBFS
CG_IAMP_TBB(7) RSSI:0x0000665C approx. -8.18 dBFS
CG_IAMP_TBB(8) RSSI:0x0000726D approx. -7.21 dBFS
CG_IAMP_TBB(9) RSSI:0x000082D5 approx. -6.05 dBFS
CG_IAMP_TBB(10) RSSI:0x00008EAA approx. -5.29 dBFS
CG_IAMP_TBB(11) RSSI:0x00009F79 approx. -4.33 dBFS
CG_IAMP_TBB(12) RSSI:0x0000AC01 approx. -3.67 dBFS
CG_IAMP_TBB(13) RSSI:0x0000BC40 approx. -2.88 dBFS
binary search:
csw=64 cmphl=3
csw=32 cmphl=3
csw=16 cmphl=3
csw=8 cmphl=3
csw=4 cmphl=2
csw=6 cmphl=3
csw=5 cmphl=3
csw=3 cmphl=2
csw=2 cmphl=2
csw=1 cmphl=2
csw=0 cmphl=2
binary search:
csw=192 cmphl=3
csw=160 cmphl=3
csw=144 cmphl=3
csw=136 cmphl=3
csw=132 cmphl=3
csw=130 cmphl=3
csw=129 cmphl=3
CG_IAMP_TBB(1) RSSI:0x000017E2 approx. -20.82 dBFS
CG_IAMP_TBB(2) RSSI:0x000022C2 approx. -17.56 dBFS
CG_IAMP_TBB(3) RSSI:0x0000369D approx. -13.63 dBFS
CG_IAMP_TBB(4) RSSI:0x000045D4 approx. -11.50 dBFS
CG_IAMP_TBB(5) RSSI:0x000059B6 approx. -9.32 dBFS
CG_IAMP_TBB(6) RSSI:0x000067E1 approx. -8.05 dBFS
CG_IAMP_TBB(7) RSSI:0x00007B8C approx. -6.54 dBFS
CG_IAMP_TBB(8) RSSI:0x00008A3A approx. -5.57 dBFS
CG_IAMP_TBB(9) RSSI:0x00009E10 approx. -4.40 dBFS
CG_IAMP_TBB(10) RSSI:0x0000AC09 approx. -3.67 dBFS
CG_IAMP_TBB(11) RSSI:0x0000BFC8 approx. -2.72 dBFS
CG_IAMP_TBB(1) RSSI:0x0000148E approx. -22.12 dBFS
CG_IAMP_TBB(2) RSSI:0x000022F0 approx. -17.51 dBFS
CG_IAMP_TBB(3) RSSI:0x0000370F approx. -13.56 dBFS
CG_IAMP_TBB(4) RSSI:0x0000466D approx. -11.42 dBFS
CG_IAMP_TBB(5) RSSI:0x00005A6C approx. -9.25 dBFS
CG_IAMP_TBB(6) RSSI:0x000068C4 approx. -7.98 dBFS
CG_IAMP_TBB(7) RSSI:0x00007C8D approx. -6.47 dBFS
CG_IAMP_TBB(8) RSSI:0x00008AA0 approx. -5.54 dBFS
CG_IAMP_TBB(9) RSSI:0x00009E6B approx. -4.38 dBFS
CG_IAMP_TBB(10) RSSI:0x0000ACC9 approx. -3.63 dBFS
CG_IAMP_TBB(11) RSSI:0x0000C06A approx. -2.69 dBFS
FPGA SetPllFrequency: PLL[0] input:20.000 MHz clockCount:4
CLK[3] Fout:20.000 MHz bypass:0 phase:114.26 findPhase: 1
FPGA PLL[0] M=64, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
CLK[1] Fout:20.000 MHz bypass:0 phase:95.03 findPhase: 1
Thanks a lot, Build 862 seems to work!
Regarding the new limesuitegui from Build 862: Is there a selection in the app or is the selection done at build time? It doesn’t detect the LimeSDR mini v2.2 with D3XX driver v1.3.0.10 as the old one did. But it seems to work with D3XX driver v1.4.0.1. I even now get a spectrum though there seem to be sigificant artifacts every 1 MHz if sample rate is 99MHz and every 2 MHz at 98 MHz. What range of spurious LO signals do I have to expect? It seems to be 25..30dB above noise level at 24dB RX gain.
LO 97MHz:
LO 98 MHz:
LO 99 MHz:
