Issue combining LimeSDR Mini v1 with the latest Windows D3XX Drivers
Recently had issues getting my LimeSDR Mini working on on two separate Windows machines, one on 10 and the other on 11, both with the latest FTDI D3XX driver. Neither one showed the LimeSDR in LimeUtil or LimeSuite. Even worse, neither would connect to the FT600 Chip Configuration Utility as described here: FAQ — LimeSDR Mini Boards 23.01 documentation. I honestly thought my part was bricked/broken and was getting ready to put JTAG headers on and go down that rabbit-hole…
Thankfully, I sanity checked by plugging the same Mini into an Ubuntu machine and it was working fine! I went back to the Windows machines, tried different USB ports, uninstalled and reinstalled the devices in Device Manager, but it still refused to cooperate. Then I decided to try the FTDI D3XX 1.3 driver (1.3.0.10 as of this writing) as opposed to the 1.4 (1.4.0.1 as of this writing). After uninstalling the 1.4 driver and installing the 1.3 one, eureka!
If this has already been recorded somewhere, I could not find it for the life of me. I’d like if somebody else can confirm they have the same issue with a clean install of the most recent D3XX driver for the Mini v1. If the same issue arises, maybe the hardware team should reach out to FTDI about the bug, but at very least put version guidance for the driver installation in the meantime.
I just went through the same issue with the FTDI D3XX 1.4.0.1 driver. I am running Windows 11 and installing the 1.3.0.10 driver is the only way Lime Suite GUI was able to recognize the LimeSDR mini as a device to connect to.
Thank you for your post, it was very helpful to me as someone extremely new to this realm!
what causes the issue that v1.4 driver do not work with limesdr mini v1? Is there any solutions for that. Main reason is that there is no windows arm version of the older driver :slightly_frowning_face:
The v1.4 driver works with LimeSDR Mini, it’s the software that’s built using v1.3 driver library, it can detect only that driver version.
The v1.4 driver provides support library with the same API, so it can be directly replaced when building software, I’ve done a build of LimeSuiteNG with the v1.4 driver support GitHub - myriadrf/LimeSuiteNG at ftdi-1.4-driver
The current problem is that both drivers v1.4 and v1.3 have the same API functions, therefore LimeSuiteNG can’t simply link to both of them at the same time, function names collide. It’s technically possible to use both, but requires some hacking in the build process.
