LimeSDR Mini v1.2 streaming fails (“No samples or timeout”), v1.3 PLL setup fails on old gateware
Hey all,
I got two LimeSDR Minis going on LimeSuiteNG (built from source, Windows 11) and I’m stuck on two different problems. Would appreciate any help.
Setup: Win11, LimeSuiteNG built from source off the develop branch, FTDI D3XX driver 1.3.0.10 (1.4.0.6 wasn’t detected by LimeSuiteNG at all; had to force-bind 1.3.0.10 via “Have Disk” on both boards).
Board 1 (v1.2, USB3.0, FW:6 HW:2 GW:1.58)
Everything configures fine, RX calibration passes, but streaming never works. Same error every time no matter what I use (FFTviewer, limeTRX --fft, limeConfig+limeTRX):
ERROR: No samples or timeout
ERROR: StreamComposite: not enough samples
Ruled out: USB port (tried both 3.0 ports), sample rate, antenna on/off (no difference), FT601 EEPROM config (checked it, looks fine, factory config). Had calibration errors at first but fixed those by maxing TxGain and pushing settings to the chip with GUI–>Chip. Streaming still times out after that.
Board 2 (v1.3, USB2.0, FW:6 HW:3 GW:1.30, older gateware)
Fails way earlier, at basic config:
ERROR: lms7002m_set_frequency_cgen:(61440000 Hz) failed
ERROR: FPGA SetPllClock: find phase, failed to write registers
Found an old 2019 thread with the same symptoms which was blamed on outdated gateware.
Questions:
  1. Board 1 - any idea what causes config/calibration to pass but streaming to always time out? Known issue with LimeSuiteNG + D3XX 1.3.0.10 on Windows?
  2. Board 2 - want to update gateware but not sure which file is right for HW rev 3 with LimeSuiteNG’s GUI programming dialog. Don’t want to brick it with the wrong one.
Thanks!
Hi @jbracken05,
I don’t recognize GW1.58 version, so I cannot comment on it.
For LimeSDR Mini V1 boards we have “Classic” gateware with latest version GW1.30 bitstream.
Recently gateware was refactored with LiteX based version and latest release is GW3.12. You can find programming file LimeSDR-Mini_lms7_trx_HW_1.2_auto.rpd for LimeSDR Mini V1 board in LimeSDR_GW_v3.12_bitstream.zip archive under LimeSDR_GW/bitstream/LimeSDR_Mini_V1/ directory.
I would recommend updating both boards to GW3.12.
Regarding LimeSuiteNG and FTDI drivers, perhaps @ricardas can provide more information.
Regards,
Vytautas
Thanks Vytautas, this is really helpful.
One question before I flash board 2 (HW:3): the bitstream file is named LimeSDR-Mini_lms7_trx_HW_1.2_auto.rpd but sits under the LimeSDR_Mini_V1 folder rather than being split by HW revision. Is this the same correct file for a HW:3 board, or is there a separate file I should be using for that revision? Just want to double check before flashing since I don’t want to risk bricking it.
Thanks again for the help.
@jbracken05 same bitstream file is used for both versions LimeSDR Mini v1.2 and LimeSDR Mini v1.3.
Regards,
Vytautas
