Hi, I am using LimeSDR-USB v1.4s with LimeSuite v20.07.2 (built from source) and srsLTE.
I have problems setting certain frequencies - I get “SetFrequencySXR(1812,5 MHz) - cannot deliver frequency” error. I can reproduce this with LimeSuiteGUI - tab “SRX” - I would type the desired frequency and would press “Calculate” button.
Then I get the following debug log:
[10:37:22] DEBUG: INT 114, FRAC 1365, DIV_LOCH 1, EN_DIV2_DIVPROG 1 [10:37:22] DEBUG: VCO 7250.00 MHz, RefClk 30.72 MHz [10:37:22] DEBUG: ICT_VCO: 255 [10:37:22] DEBUG: TuneVCO(SXR) - VCO too low [10:37:22] DEBUG: VCOL : csw=0 tune fail [10:37:22] DEBUG: ICT_VCO: 255 [10:37:22] DEBUG: TuneVCO(SXR) - VCO too low [10:37:22] DEBUG: VCOM : csw=0 tune fail [10:37:22] DEBUG: ICT_VCO: 255 [10:37:22] DEBUG: TuneVCO(SXR) - VCO too low [10:37:22] DEBUG: VCOH : csw=0 tune fail [10:37:22] DEBUG: Selected: VCOH [10:37:22] ERROR: SetFrequencySXR(1812.5 MHz) - cannot deliver frequency
I found that the error happens for frequency ranges: 1710-1920MHz, 859.5-964.0MHz, probably others.
I found out that if I change(usually increase) the Reference Clock from 30.72MHz to 36.72MHz, for example, the desired frequency will be accepted.
I also found that LimeQuickTest fails:
[ TESTING STARTED ] ->Start time: Fri Sep 18 10:55:43 2020 ->Device: LimeSDR-USB, media=USB 2.0, module=FX3, addr=1d50:6108, serial=0009081C05C1361B, HW=4, GW=2.23 Warning: USB3 not available Serial Number: 0009081C05C1361B Chip temperature: 53 C [ Clock Network Test ] ->FX3 GPIF clock test Test results: 23803; 27559; 31315 - PASSED ->Si5351C test CLK0: 17554 / 17554 - PASSED CLK1: 17554 / 17554 - PASSED CLK2: 17554 / 17554 - PASSED CLK3: 17554 / 17554 - PASSED CLK4: 17554 / 17554 - PASSED CLK5: 17554 / 17554 - PASSED CLK6: 17554 / 17554 - PASSED ->ADF4002 Test Result: 10 - PASSED ->VCTCXO test Results : 5112941 (min); 5113077 (max) - PASSED ->Clock Network Test PASSED [ FPGA EEPROM Test ] ->Read EEPROM ->Read data: 13 01 18 13 01 19 03 ->FPGA EEPROM Test PASSED [ LMS7002M Test ] ->Perform Registers Test ->External Reset line test Reg 0x20: Write value 0xFFFD, Read value 0xFFFD Reg 0x20: value after reset 0x0FFFF ->LMS7002M Test PASSED [ RF Loopback Test ] Note: The test should be run without anything connected to RF ports ->Configure LMS CGEN: Freq=80 MHz, VCO=2.4 GHz, INT=77, FRAC=131072, DIV_OUTCH_CGEN=14 CGEN: Freq=80 MHz, VCO=2.4 GHz, INT=77, FRAC=131072, DIV_OUTCH_CGEN=14 CGEN: Freq=491.52 MHz, VCO=1.96608 GHz, INT=63, FRAC=0, DIV_OUTCH_CGEN=1 CGEN: Freq=491.52 MHz, VCO=1.96608 GHz, INT=63, FRAC=0, DIV_OUTCH_CGEN=1 SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase SetPllFrequency: error configuring phase LML TX phase search FAIL Failed to set sample rate ->RF Loopback Test FAILED => Board tests FAILED <= Elapsed time: 2.29 seconds
I use the LimeSDR device with external power supply (12V, 1.5A).
Eventually I got another SDR device and the issue was not present there.
I have already posted this same topic as LimeSuite GITHub Issue:
The conclusion there was that I face a hardware issue.
Still I was advised to post the issue here as well, before starting RMA process.
Could you please share some comments?
Thank you.
