Hi Zack
here you go all under windows 10 - some times it passes and other times it hangs at testing LMS702 registers or other times it hangs at RF loop back.
Sometimes the test program completes but reports a fail board.
Very rarely does it pass the tests.
All the other units pass 100% of the time.
Here are the outputs of the testing showing it hangs the program.
Regards Tim
->Start time: Fri Jul 27 15:22:52 2018
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D40EC17CEF786, index=0
Serial Number: 1D40EC17CEF786
->REF clock test
Test results: 64918; 12579; 25776 - PASSED
Results : 6710992 (min); 6711151 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 06 1C 12 06 1C 02
->FPGA EEPROM Test PASSED
HANG UP
->Start time: Fri Jul 27 15:28:40 2018
->REF clock test
Test results: 13372; 26569; 39766 - PASSED
Results : 6711030 (min); 6711187 (max) - PASSED
->LMS7002M Test PASSED
HANG UP
->Start time: Fri Jul 27 15:33:17 2018
->REF clock test
Test results: 63937; 11598; 24795 - PASSED
Results : 6711029 (min); 6711186 (max) - PASSED
Read(64 bytes) failed
RegistersTest() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 8.51 seconds
