Hi
Impossible to make my Lime Mini to work, and looks like I am not the only one.
Is there a way to reset via command line, or any other magic tweak?
Tested on Linux Ubuntu, Windows 7, Windows 10
Worked once 6-month ago during 10 minutes in RX only with sdr console for listening to FM Radio
Now impossible to replicate
Thanks
Daniel
LimeUtil --info
Version information:
Library version: v20.10.0-g1480bfea
Build timestamp: 2020-11-10
Interface version: v2020.10.0
Binary interface: 20.10-1
System resources:
Installation root: /usr/local
User home directory: /home/daniel
App data directory: /home/daniel/.local/share/LimeSuite
Config directory: /home/daniel/.limesuite
Image search paths:
- /home/daniel/.local/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
Testing
->Start time: Wed Nov 11 23:26:59 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D4C20586F8373, HW=2, GW=1.30
Serial Number: 1D4C20586F8373
Chip temperature: 62 C
->REF clock test
Test results: 51836; 65033; 12694 - PASSED
Results : 6711088 (min); 6711244 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 02 0B 13 02 0B 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
Failed to read samples: Timeout
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-14.0 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.0 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 4.82 seconds
