Windows machine (USB3)
Lime Suite - option - connection setting --> nothing appear.
My PC has not a word “unrecognized device” in Device manager in Japanease.
I do down load USB drivers ---- what to do next?
Mac
Lime Quick Test --> “No device connected”
Ubuntu machine
LimeSuite GUI --> “Error no device connected”
There are Red LED lit and Green flashing.
USB current is 310mA.
i connect RTL-SDR, HackRf One and LimeSDR mini.
Then I do “Lsusb” on terminal.
Result is as follews.
oz@oz-desktop:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 004: ID 0403:601f Future Technology Devices International, Ltd
Bus 001 Device 003: ID 0a6b:000f Green House Co., Ltd FlashDisk
Bus 001 Device 006: ID 1d50:6089 OpenMoko, Inc.
Bus 001 Device 002: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
oz@oz-desktop:~$
I connect LimeSDE-Mini without power meter. Result is as follows.
Bus 002 Device 002: ID 0403:601f Future Technology Devices International, Ltd
Bus 001 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
oz@oz-desktop:~$ sudo LimeSuiteGUI
[sudo] oz のパスワード:
Gtk-Message: 18:58:06.955: Failed to load module “canberra-gtk-module”
(LimeSuiteGUI:1864): IBUS-WARNING **: 18:58:06.958: The owner of /home/oz/.config/ibus/bus is not root!
(LimeSuiteGUI:1864): Gtk-WARNING **: 18:58:07.987: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 17
Yes, from terminal with sudo, LimeSuiteGUI is kicked OK,
but there are “warning” on terminal as before. Is it OK?
LimeSuiteGUI kicked from GUI, I can see options -> connection setting -> LimeSDR Mini [USB 3.0], now.
I try from beginning.
Thank you Zack.
