I have a problem with my purchased Lime SDR Mini cs-lime-05 that the USB port connection no longer works.
What I note when I connect it is that it is signaled that an unknown USB device is connected but it is not recognized.
On a Windows 7 computer he will indicate Code 43 as a message. Both Green and Red combi LED are constantly lit on the print board.
After visiting the site of Lime Microsystems | LimeSDR Mini
driver reinstalled and the test program will not work due to not found USB device.
Also 5V voltage controlled and USB-2 Hub applied give no change and the USB connection cannot be used.
73"Jack PA0BOJ
